Results 1 to 10 of 11
Thread: In the clutch of frustration
    Broome, WA
    Hi there, have had the clutch and clutch fork replaced in my 95 defender. It has been in the car for just over a week. At first it was very light to use and pleasant to drive, I actually had a smile on my face.
    But...
    Now, like before I had the clutch and fork replaced, it is not smooth when letting it out and is even more more difficult to use when the air con is on.
    The slave cylinder was replaced 2 years ago, but isn't an original part.
    Could the condition of either the slave or master cylinder effect the quality of clutch operation and would they be worth replacing as a next step solution?
    Does anyone else have the problem of the clutch becoming harder to use with the airconditioning on and how have you solved it?
    On a positive not, when I had the clutch replaced I had the front drive flanges replaced with maxi drive units. They seem to have done the trick! For
    once.
    Dan
    Quote Originally Posted by Broome Defender View Post
    But...
    once.
    Dan
    well as having had 8 defenders but non with Ac i can't comment on the differance with the ac on . But i would be surprised if it would make a differance as i can see anyway they waould cross paths to affect each others operation.
    I would say replacing the slave could be the next best way to go. Check the flexy pipe that goes in to the slave (just above it ) people forget about this bit but this can cause some problems . then if still no joy then i would say the master . The slave always goes (in my findings) before the master
    But still can't work out why the ac would affect the glutch pedal
    Don't about here but in the Uk 2 years is a bloody good innings for a slave cylinder
    95 300 Tdi Defender 90
    99 300 Tdi Defender 110
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
    Broome, WA
    Thanks for the tip! I'll check the pipe and order a slave cylinder. Hopefully that fixes it.
    By the way Mr Reads90, were you in Broome at Roebuck Plains Roadhouse at any stage last year towing a camper trailer? I seem to remember meeting a guy driving a bright blue 90 with no aircon?
    Last edited by Broome Defender; 3rd February 2007 at 07:54 PM. Reason: forgot to complete message
    Clutch is sticky? Maybe it feels like you have to push the pedal over a hill to get it out of gear? Inconsistent uneven pedal travel? Sqeaks, squeals? Pedal sticks down? Just replaced the master cylinder after two years of irritation. Wow, what a difference. Best fifty I've spent in a long time. Don't know how much a slave cylinder is - call Karcraft and get them to send you one of each and do it all in one go. Cheers Simon.
    Last edited by abaddonxi; 3rd February 2007 at 08:42 PM. Reason: Lost all bloody line breaks
    Could it be a leak in the vacuum hose to the booster?
    Allestree , its all good.
    Try rebleeding / replacing the clutch fliud with a one man bleeder pot. Worked a treat for mine and that was only a week out of the shop for total clutch replacement.
    '99 Tdi 300 130 Twin Cab
    When I'm here I want to be out there.
    Forgot to say that I had new clutch six months ago or so. Made no difference.
    Simon.
    Yeah i was about end of april begining of may last year
    Yeah if i rember you were in a white 110 300 tdi
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
    Broome, WA
    Simon, it's doing exactly what you stated in your first reply, thanks for the advice. I'll order the both the slave and master cylinders, any tips on the replacement of the master?
    Reads90 that was me in the 110 at Roebuck, you obviously got home safely and I hope you enjoyed it over here?!
    Dan
    Dan
    Yeah got back fine after a trip to darwin and the cape. But we will be back to broome soon. In fact poping over to W/A at christmas
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
