Results 1 to 8 of 8
Thread: empty bolt hole is it supposed to be?
    Hi All
    I was looking under the Rangie and noticed an empty bolt hole.
    I guess it should have a bolt but haven't noticed it empty before.
    Maybe it worked loose?
    What is the bolt hole for?
    Yes I know a bolt but a bleed/drain hole or what?
    In case the pic isnt clear it's just behind the sump.
    tombraider Guest
    Drain.. Leave it open.
    howzat for a quick reply.
    Thanks mate
    Two Rocks WA
    Steve see the square bolt next and slightly above your hole, thats what u unscrew to fit into your hole if you are doing lots of water crossings to stop the water getting in to the clutch and slipping. But as toombraider has said leave it open.
    Brad
    Range Rovers Have Charactors inside them
    LROCWA Ex member 23 years
    1971 Series 2A
    2004 Discovery2a V8 Auto
    2003 Discovery2a TD5 Manual
    1982 4door man (sadly now gone)
    1989 Vogue auto
    2011 TDV8 Vogue
    What would life be without a Rangie?
    Quote Originally Posted by Bradtot View Post
    Brad
    They do say you learn some thing new every day !
    So if you were doing a deep water crossing you would block up the hole or not?
    Not that I really intend to as I have no snorkel and the Lucas electrics are a bit dodgy at the best of times!
    Or is this just something you would do for LOTS of deep wading and muddy stuff, like all day.
    Caboolture.Qld
    No, If you are going to do a water crossing, block the hole.
    how can you tell youve bought a serious 4x4 and not a toy one?
    They come with wading plugs as standard.
    South Yundreup,WA.
    Check your LR tool kit, there should be a couple of wading plugs in there.
    2011 Discovery 4 TDV6
    2009 DRZ400E Suzuki
    2003 WK Holden Statesman
    Departed
    98 Ducati 900SS Gone & Missed
    Facta Non Verba
