Thread: Fuel access panel
    Sunny Pucka
    Fuel access panel
    feul access.jpg Blknight.aus showed me how to do this. Just need to get the pic bigger. The measuerments are there but the pic is too small. The panel its self is 200mm X 200mm.
    Jannali - NSW
    Here are further details to do this access hole:
    Defender Td5 - Fuel Pump Access Hole
    Mulgo Pty Ltd
    Expedition vehicles & equipment
    69 Anderson Road, Mortdale NSW 2223
    p 0438 183 507 / www.mulgo.com.au
    Purchase your 4wd gear online:
    www.expeditioncentre.com.au
    follow us on facebook:
    facebook.com/expeditioncentre
    how are those hinges and the stop plate flange rivets holding up?
    Jannali - NSW
    no issues - still going strong. just take the 2.5mm aluminium and stainless steel rivets.
    if you will be in Cooma you can check it out.
    cheers,
    daniel
    Mulgo Pty Ltd
    Sunny Pucka
    Mines holding up well. Only had to replace the screw that holds the flap closed.
    Easo
