Results 1 to 10 of 20
Thread: flame trap, what can I put in it?
    Hi All
    I have an 81 RR I looked in the flame trap to clean it and it's empty.
    I think there is supposed to be some sort of wire filter, (wirewool type stuff).
    What can I use to fill the flame trap? Clean comments only please
    I haven't asked if the Landy Stealers sell the filter but the housing & filter costs over $100 !!
    So what can I use that's cheap?
    Adelaide Hills. South Australia
    I had mine out the other day & it was a type of woven wire mesh wool. *** Not steel wool.
    I suspect a couple of those stainless steel scouring pads would do the same job.
    RR5L Guest
    I bought one from LRA in Thomastown a couple of years back and it was about $40 from memory New.
    coarse stainless steel wool will work.... but its a little dodgey.
    The mesh in some LR flametraps appears to be aluminium. I tried a technique I used on my old RR HiLine and the mesh dissolved in the County's flame traps.
    The pics below shows how the Rangie's flame trap material looked before and after a soak in caustic soda (this stuff needs treating with care!) then a wash in water.
    Before:
    After:
    Ron
    S.W. Sydney
    Wire wool old scouring pad works a treat
    Tony
    Quote Originally Posted by RR5L View Post
    $40 for a bit of steel wool !
    I suppose I had better get one
    Adelaide Hills - SA
    Real basic question: what does a flame trap do? Must be a petrol thing as I've never heard of one on my diesels.
    It traps flames
    It's got something to do with preventing the flames/explosion from a back fire getting places they shouldn't be.
    Also something to do with allowing gasses to escape and not build up causing gasket failure. I think?
    I know they are fitted to some diesels dunno about landy's though. Some one will tell you.
    Alstonville...is near Byron Bay
    Just been there.....Hangover....
    Read my recent post titled: "oil leak goes bad - uh oh."
    Nice pix Ron.
    When I eventually got the wire out, I washed in petrol and let it dry - good as new.
    GQ
