Results 1 to 10 of 11
Thread: bug or feature ?
    Nov 2006
    Tasmania
    bug or feature ?
    Came home the other night and had the lights on. Turned the key to stop the engine but it would not stop. Tried it a few times and did not stop. I think the fan stopped and the lights in the dash weren't as bright.
    As soon as I turned the light of the engine stopped
    Matt
    Jun 2003
    Launceston, Tasmania
    sounds like an electrical gremlin to me.
    1994 Discovery TDi
    2004 Discovery 2 TD5
    2010 Discovery 4 TDV6
    St Helena,Melbourne
    4.28 MB
    Ah, thats the factory intergrated turbo timer/ headlight gizmo.
    Not a feature i would pay extra for.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Has it been raining there in the past 24 hours. If so then there's you problem. Nah not the rain, lucas mixed with water. Somthing under bonnett has shorted out
    95 300 Tdi Defender 90
    99 300 Tdi Defender 110
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
    Dalby
    If the alternator was still spinning with the engine and the electricals switched off I'd check to see if your alternator still charges.
    It isn't the cause of your problem but it may have occurred because of it.
    Nov 2006
    Tasmania
    I thought I found all the leaks
    But it hasn't rained that time or before it. Also we could need some rain (on tank water here).
    I thought about the factory integrated turbo timer but could not find it in the handbook
    So it looks like my electric is killing its self slowly. Why am I not surprised. Looks like that Disco has many features I'm not aware of
    Edit: I tried it again today and of course it didn't do it. I had the boat at the back and just thought maybe the electric of the boat was wet and had something to do with it ??
    Matt
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by Roadrunner View Post
    Matt
    Ah grasshopper, that could be it, i bet it only does with the trailer plug connected ?
    1974 VW Kombi bus
    Alstonville...is near Byron Bay
    If you have a D1 Disco I know exactly what it is - on a D1 on the instrument binnacle there is a button, left side top inner, for the "extra" driving lights, and if you don't have them but the button is depressed (ON) then there's the issue. That's provided your taillights are cross wired - as in - when you hit the brakes and the otherwise unused foglights are used also as braking lights - simple! LOL
    GQ
    (I'm actually being serious.....)
    Yass NSW
    As our motto at work says
    It's not a bug its a free feature.
    Good luck finding it.
    I think I made a descriptive mistake re my previous post.
    The button on the instrument binnacle (top left inner) operates the rear fog lights (hi intensity red on the body, not the bumper lights).
    Anyhow, if this switch is somehow crossed, you'll probably have what you've described and something else maybe - press the brake pedal and your hi beam should come on!
    And the engine will keep going after the you've turned the key to 'off'.
    I'm not sure about the update D1 (been a while since I was in one) but from memory they're pretty much the same as the pre update version.... methinks....
    the long and the short of this, is, don't turn on the rear fog lights and then see what happens......
    GQ
