all done with a drill a vice and a die grinder, and a bit of marking out![]()
my swivel balls that is.
will give me between -1deg and +13deg with my lift. now to refit the lot and get an alignment done!
cheers phil
Do you think you should drill an extra hole and tap the axle so that it does not twist back? (does that make any sense???)
I'm normally happy to scratch mine, but hey, it takes all kinds.![]()
The Ugly Duckling-
03 Defender Xtreme, now reduced by 30%.
a master of invisibleness.
The holes arent curved in line with the radius ? looks like they will bind when you try to rotate them unless they are oversize and if so they are now paperweights.
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
Thats some massive slots![]()
mine are about half that to suit 120mm front bumpstop height,
you must have a huge lift![]()
with the super serious amounts of torque when you hit the brakes you will need some form of shims either side of the bolts in the slotted holes to stop them rotating. i dont think just doing the bolts up tight will be enough.![]()
1995 Defender 110 300TDI :D
1954 86" Series 1 Automatic :eek:
Ex '66 109" flat deck, '82 109" 3 door, '89 110 CSW V8, '74 Range Rover, '66 88" soft top, '78 88" soft top, '95 Disco ES V8, '88 Surf, '90 Surf, '84 V8 Surf, '91 Vitara.
a couple of decent grub screws will prevent that happening......after the alignment has been done.....
this method is used quite a bit on landies......there arent too many others out there you can do this to....
on those cars you need to remove the diff and cut off and reweld the brackets in order to rotate the whole
diff assembly to acheive the same result.....
And of course this will all be certified.....................
you wouldn't want your insurance co to find this after an accident.................
must be BIG GRUB SCREWS to hold most of the 2 ton weight of a land rover.............in a 75mm radius........... in a panic stop.
better you than me mate![]()
