Results 1 to 10 of 19
Thread: Home brewing
    Sunny Pucka
    Home brewing
    Any good tips for the new brewer. Just got a coopers micro brew kit as early Bday pressy. First brew is on the way. But any tips to enhance the experince/% would be good.
    Don't skimp on the sterilisation.
    Don't substitute sugar.
    Don't drink it all at a sitting.
    Simon.
    Barmera .SA.
    Talking
    Be clean, be scrupulessly clean, equipment, bottleing gear, bottles, yourself, all sterile. Nappy San is Sodium Metabisulphate, to a great extent, cheap and quick plunge steriliser. Buy new spare buckets and syphon hoses, and never use them for anything else. I'll check to see how to get a text attachement posted. I have a text file of many different recipes. will post it up here soon.
    The Coopers kits are good, follow the instructions exactly. The longer you let Coopers age, the better it will be, and it is like that NSW Old beer, the nice dark beer mmm beer, sorry, when you see the sediment which is dead yeast cells (vegemite), it's too late, you may as well have another one, cause it will hurt tomorrow anyway.
    Shorty.
    Barmera .SA.
    Talking Here it is.
    One 63 Kb txt file, full of beer recipes.
    Don't ask me! I only found them. May only be of curiosity value.
    These are direct logs from the Zymergy Echo, to disk. The names,
    comments, etc are still on them. In fact, nothing has been added or
    removed, no artificial flavours, artificial colours, fillers or
    preservitives were added to these messages to make them less than they
    really were, and are.
    One thing, I stopped doing this for 8 months so there is a BIT of a gap.
    Area Zymurgy, Msg#94, 09-10-92 07:21:48
    To: Denis Dubuc
    Subject: Re: Heineken Beer
    Here is a simple, yet very close recipe to Heineken Dark Beer.
    Ingredients: One (1) Arkell Kellar Premium Lager 1.8 kg
    1 oz Hallertauer hops
    250 grms of roasted barley
    1 kg dry malt extract
    1) Crack the husks of the grains and place same in cheese cloth and knot.
    2) Place in 3 litres of boiling water and steep for 30 mins.
    3) Add the Arkell lager, the dry malt, and 1/2 oz of hops.
    4) Boil for one (1) hour.
    5) Put the wort into primary fermenter filled to the 5 gallon mark.
    6) Add the remaining 1/2 oz of hops and pitch the yeast.
    Proceed as usual.
    The only problem with this recipe is you might get a chill haze with the
    beer. I don't use Irish Moss but some say to add 1/2 tsp of Irish Moss
    to the boil 15 minutes prior to adding the wort to the primary pail.
    Enjoy!
    --- msgedsq 2.0.5
    * Origin: PRO COP "Mie spel chekher iz awn the phritz" (1:221/178)
    SEEN-BY: 8/0 1 8 10/8 13/13 207/213 925/60 973/1 980/2
    Area Zymurgy, Msg#74, 14-10-92 21:35:20
    To: Mark Engebretson
    Subject: boil or not to boil
    In response to your request for a Russian Imperial Stout recipe I submit a
    recipe that has done well for me (3 ribbons):
    9 lbs Extra Dark Dry Malt Extract
    3 lbs honey
    1/2 lb black patent malt (well crushed)
    2 lbs #120 Crystal
    40 HBU bittering hops
    3 oz aroma hops
    3 oz dry hop
    Use whatever yeast you like, and use a lot! This should be fermented in the
    65-72 F range as high gravity worts tend to produce a lot of phenol at warm
    temps. The great amount of hops are neede because of the high gravity. Oh,
    and steap the black malt in one gallon water, bring to a boil (yes, boil...
    black malt has so little husk that boiling is no problem) strain and go as
    for regular brews...
    Rick
    --- Maximus/2 2.01wb
    * Origin: No Tarmac Brewing (1:109/131)
    Area Zymurgy, Msg#96, 16-10-92 10:48:00
    To: Jerry Kassebaum
    Subject: Re:Pumpkin Beer???
    JK> Anyone have a good, tested recipe for pumpkin beer? About all
    JK> Papazian has is "Used boiled pumpkin. Spices, too, if you'd like."
    JK> How long do I boil how much pumpkin? Other specifics, too, please.
    JK> Thanks!
    Disclaimer: I've never made pumpkin beer, but I've improvised with
    excellent results on several batches.
    1. For my tastes, I'd think a pumpkin beer would be best as a dark ale..
    some dark malt, but because of the pumpkin not as much hops...
    perhaps 3/4 Oz. Goldings flavor, 1/3 oz. Saaz aroma. With a truly
    dark malt that won't seem very hoppy.
    2. Baked, not boiled, pumpkin would give stronger results in the flavor.
    After baking, take ~1C. of pumpkin out of the skin and put in a muslin
    or cheesecloth bag. Do not mash, but chop into 3/4" cubes.
    (To bake pumpkin, cut in half and scrape flesh remove seeds and other
    internals. Place on cookie sheet or aluminum foil, bowl-style, inside up,
    in 350 deg. oven until fork penetrates easily (varies a lot by pumpkin
    size and flesh thickness). Cook a bit less than this for beer purposes
    but leave the rest in to make pie out of or whatever.)
    3. After boil, add pumpkin bag, 1T. ground cinnamon, 1t. ground nutmeg,
    fresh if possible. More spice to taste. Allow to cool.
    4. Before diluting & pitching yeast, remove pumpkin bag.
    OK, so this isn't the tested recipe you asked for. But you should have
    good results; I'm enjoying it in my mind already. I think after my next
    batch of Ain't Misbehaving I'll try this one myself.
    Mike
    * Origin: Beer beer beer beer beer beer. A six-pack... (1:260/244.0)
    Area Zymurgy, Msg#99, 16-10-92 12:01:02
    To: Jerry King
    Subject: Beer, Dark, German Style
    Here's a simple recipe for a moderately dark English-style ale.
    3.3 lb (1 can) John Bull amber malt extract
    3 lb Munton and Fison dark dry malt extract (powder)
    2 oz Kent Goldings hops
    1 pk Edme ale yeast
    3/4 cup corn sugar
    Boil a couple of gallons of water. Remove from heat, add malt.
    Return to heat and boil 30 minutes. Add half the hops. Boil another
    15 minutes and add the rest of the hops. Boil another 15 minutes, then
    cool the wort, pour it into your fermenter, add cold water to bring the
    total volume to 5 gallons, and pitch the yeast when it's at room temp.
    Ferment until the bubbling stops (about a week), then boil a pint of
    water with the corn sugar. Cool it, then mix it with the beer in a
    bottling bucket. Siphon into bottles, cap, and store for at least
    three weeks.
    Here's a recipe for a stout that I brewed last July. It's all gone
    now, sadly.
    6.6 lb Munton and Fison dark malt extract syrup
    1/2 lb roast barley grains
    1/4 lb 2-row malted barley
    1/4 lb chocolate malt (grain, not milkshakes!)
    1/2 lb cracked wild rice
    1.5 oz various hops (cleaning out my cupboard)
    1 tsp ground cinnamon
    1/2 cup dark Brer Rabbit molasses
    2 cups brewed Gevalia coffee
    1 pk ale yeast
    3/4 cup corn sugar or 1 cup dried malt extract for bottling
    As you can see, it's hard to hurt a stout. :-) Steep the grains for
    an hour or so at 150-180 degrees, then drain them into your brewpot
    through a collander. Trickle hot water through them until all the
    sweetness is extracted into the pot. Add your syrup, cinnamon, coffee
    and molasses, and boil for an hour. Toss half the hops in after 30
    minutes, then the rest 5-10 minutes before you're done. Cool,
    transfer to fermenter, add water, add yeast, ferment for a week or so,
    add sugar as in the first recipe, bottle and wait several weeks before
    popping the top.
    Note that neither of these are German-style beers. For that, you'll
    need to use a lager yeast and a cold room for fermenting, which will
    take much longer.
    If you want to pump up the alcohol content, use more malt extract.
    Note that as you approach 7-8%, the alcohol will tend to kill the
    yeast, and you may have trouble carbonating your beer. Personally,
    I find high-alcohol brews to have an objectionable taste.
    If you want darker beers, use more chocolate and/or black patent
    malt. Basically this is malted barley that has been roasted to
    varying degrees of wicked blackness.
    --- Maximus 2.01wb
    * Origin: The Spare Computer (1:282/62)
    Area Zymurgy, Msg#94, 17-10-92 20:51:04
    To: All
    Subject: Recipes
    I see frequent requests for recipes on the conference. Since I do not
    routinely type up my recipes I do not post everything that I make.
    However, The Barley Corn, an east coast beer newspaper somewhat like The
    Celebrator, commisioned an article on Vienna/Marzen/Oktoberfest from me.
    I humbly post this for your consumption. George Fix's book _Vienna_ has
    greatly influenced my view of what these beers are. So, for further
    reference...
    ___________________________________
    Excerpted from Barley Corn, Vol. 2 No. 5
    Oktoberfest for the Home Brewer
    When the general public is asked to name some specialty beer
    styles, one that is frequently mentioned is Oktoberfest. There
    is a folk lore, that has developed by word of mouth, that this
    beer is a special one brewed for a very serious party - the
    annual Munich Oktoberfest. So, for their very own serious
    party, one of the first specialty beers that home brewers try to
    brew is this Oktoberfest beer.
    The beer served at Oktoberfest is actually named Marzen. This
    is the German name for the month of March, but this is actually
    more of a brewing method than a style of beer. Until the 1840s,
    Marzen beer was brewed in the spring and stored in cold
    cellars, ice houses and ice caves in the summers before
    refrigeration was available. Without refrigeration it was
    impossible to brew beer in the summer. So, what was made in
    the spring had to last all summer. The last of this beer was
    drunk at the Oktoberfest. Thus comes the alias: Oktoberfest
    beer. With the advent of refrigeration this long aged beer was
    no longer a necessity. However, beer revolutionaries Anton
    Dreher and Gabriel Sedlmayr recognized the unique
    smoothness and flavor associated with this beer and enabled
    the transition of the Marzen style into the Industrial Age.
    In order to reproduce a true Marzen beer we must first define
    what we are trying to make. This beer is an amber, malty, full
    bodied beer with a balanced bitterness and subtle, but
    noticeable noble hop aroma. This translates to a starting
    specific gravity between 1.052 and 1.064 (13-16 Plato), alcohol
    between 4.8 and 6.5%, hopping rate between 6.6 and 8.83
    HBUs (22-28 IBUs), and color between 8 and 12 degrees SRM.
    The most important features of this beer are subjective and
    cannot be easily put into numbers. George Fix in the Brewer's
    Publication book Vienna (highly recommended) states that the
    best descriptors for this beer are elegance, softness,
    complexity, and balance. He believe this is brought about by
    using the highest quality ingredients, long aging, a proper
    yeast, and meticulous handling. I believe that meticulous
    handling is the key.
    At least 85% of all home brewers never go beyond brewing
    beer with malt extract. There are kits available for Oktoberfest,
    but all of them miss the Marzen mark. I recommend
    Alexander's unhopped pale malt extract in all cases where
    extract is called for. This is the palest extract available. This
    way we can get the color and character that we choose by
    adding our choice of specialty malts, not the manufacturers
    choice.
    I present three Marzen recipes in increasing order of
    challenge. These are based on extract, partial mash, and an all
    grain formulation.
    Extract Oktoberfest for 5.5 gallons
    2 4 lbs cans Alexander's Unhopped Pale Malt Extract
    1 lb 40 Lovibond Crystal Malt
    7 HBU noble bittering hops (Saaz, Tettnanger, or Hallertauer)
    for 60 minutes
    1/4 oz Saaz aroma hops for 10 minutes
    1 tsp. Irish Moss
    lager yeast
    3/4 cup corn sugar or krausen to bottle
    * Original gravity: 1.052
    * Terminal gravity: 1.012
    Procedure:
    Add the crushed crystal malt to one gallon cold water.
    Slowly bring the water to 165 F, over 30 minutes. Pour the
    grain through a colander, reserving the liquid. Rinse the grain
    with hot water and add all of the collected sweet wort to the
    kettle. Add water to the kettle, reserving space for the extract.
    It is preferable to boil the entire brew. This will make a
    noticeable flavor difference. Bring the water to a boil for 15
    minutes. Remove the pot from the heat, to avoid scorching,
    and add the extract and bittering hops. Boil this mixture for 60
    minutes. 15 minutes before the boil is over add the Irish Moss.
    10 minutes before the boil is over add the aroma hops. Chill
    the beer to 55 F and pitch the yeast. Ferment at between 50
    and 55 F for two weeks. Transfer to a secondary fermenter and
    age for 6 weeks to 6 months at 33 F. Bottle or keg, as desired.
    Partial Mash Oktoberfest for 5.5 gallons
    1 4 lb can Alexander's Unhopped Pale Malt Extract
    1 lb Laaglander Extra Light Dry Malt Extract
    3 lbs Pilsener Malt (use Klages or Lager malt as a substitute)
    1 lb Cara-Pils Malt
    8 HBU noble bittering hops (Saaz, Tettnanger, or Hallertauer)
    for 60 minutes
    1 tsp. Irish Moss
    lager yeast
    * Original Gravity: 1.055
    * Terminal Gravity: 1.012
    Procedure:
    Add 1.33 qts/lb, 6.65 qts, of water at 165 F to the
    crushed grain. Stabilize at 151 F. Mash for 45 minutes, careful
    not to allow the temperature above 158 F. Boost the
    temperature to 160 F and sparge with 6.65 qts water at 165 F.
    Add water, reserving space for the extract, and bring to a boil
    for 30 minutes. Remove the pot from the heat, to avoid
    scorching, and add the extract and bittering hops. Boil this
    mixture for 60 minutes. 15 minutes before the boil is over add
    the Irish Moss. 10 minutes before the boil is over add the
    aroma hops. Chill the beer to 55 F and pitch the yeast. Ferment
    at between 50 and 55 F for two weeks. Transfer to a secondary
    fermenter and age for 6 weeks to 6 months at 33 F. Bottle or
    keg, as desired.
    All Grain Oktoberfest for 5.5 gallons
    10 lbs Pilsener Malt (use Klages or Lager malt as a substitute)
    1 lb Cara-Pils Malt
    8 oz 10 Lovibond Crystal Malt
    4 oz 60 Lovibond Crystal Malt
    4 oz 120 Lovibond Crystal Malt
    9 HBU noble bittering hops (Saaz, Tettnanger, or Hallertauer)
    for 60 minutes
    1/2 oz Saaz aromatic hops for 10 minutes
    1 tsp. Irish Moss
    lager yeast
    * Original Gravity: 1.059
    * Terminal Gravity: 1.013
    Procedure:
    Perform either a double decoction or a temperature step
    infusion mash. You will get a slightly higher extraction rate
    with the traditional decoction mash, but an equally good beer
    can be made with the simpler infusion mash. Use a
    sacharification rest in the high range, 153 F is a good goal. For
    good references see Brewing Lager Beer by Greg Noonan and
    The Complete Handbook of Home Brewing by Dave Miller. For
    this beer I favor the approach detailed by Miller. I use 1.33
    qts/lb, around 4 gallons, of treated brewing water (preboiled). I
    dough-in with this water at 135 F, stabilizing at 122 F for a 30
    minute protein rest. Immediately boost to 155 F; after 30
    minutes boost to 155F again. Sparge to collect 7 gallons. Boil
    vigorously (very hard) for 30 minutes. Add the bittering hops
    and maintain a rolling boil for 60 minutes. 15 minutes before
    the boil is over add the Irish Moss. 10 minutes before the boil
    is over add the aroma hops. Chill the beer to 55 F and pitch the
    yeast. Ferment at between 50 and 55 F for two weeks. Transfer
    to a secondary fermenter and age for 6 weeks to 6 months at
    Notes on Yeast and Fermentation
    A real Marzen is fermented at cool temperatures with lager
    yeast. Making an Oktoberfest ale at room temperature with
    these recipes is going to turn out a tasty beer. But the elegant
    smoothness associated with this beer is going to be missing.
    Even a lagering of 2 weeks is going to make a big difference.
    I must warn the home brewer away from dry yeasts. These are
    full of dead yeast and bacteria. The widely available Wyeast
    products are your best bet. The Wyeast No. 2308 is a
    Weihenstephan (the Bavarian National Brewing Academy)
    culture that produces a slightly fruity beer that is appropriate
    for this style. The Wyeast No. 2206, called the Bavarian lager
    yeast, is another Weihenstephan culture that accentuates malt
    character. In preparing the Wyeast cultures it is important to
    pitch an appropriate quantity. I recommend that the home
    brewer begin the process 1 week before the brew date. Whack
    the package as per the instructions. If the yeast is fresh the
    package will be swollen within 48 hours. Prepare 1/2 gallon of
    yeast starter by boiling 8 oz (weight) of dry malt extract in
    water. Inoculate the chilled starter with the yeast from the
    package. Ferment with an air lock until the yeast flocculates.
    This should provide you with around 15 grams of yeast slurry.
    To pitch the yeast pour the beer off and add the yeast
    sediment to the fermenter with your beer. It is very important
    to oxygenate your beer. This can be done by, carefully,
    pouring your chilled wort from a great height into the
    fermenter. All of the dissolved oxygen will be metabolized by
    the yeast within 5 minutes. This amount of yeast, with good
    oxygenation, will give you a quick start at 55 F. If you choose
    to use less yeast, or have poor oxygenation, you will have a
    slower start, especially at cooler temperatures.
    ___
    X WinQwk 2.0 #0 X Unregistered Evaluation Copy
    Area Zymurgy, Msg#76, 22-10-92 00:15:00
    To: All
    Subject: Pumpkin Beer
    Re: Pumpkin Beer
    By: David Burns #0 @1:150/2 FIDOnet
    > Every time I walk past a nearby grocery store and see all the pumpkins out
    > front for 9 cents/lb, I keep thinking about what it would taste like in a
    bee
    > Does anybody have a good recipe for a pumpkin ale?
    From Cat's Meow II
    Chapter 13: Historical Interest
    Pumpkin Ale
    Source: Thomas Manteufel (tomm@pet.med.ge.com)
    Digest: Issue #748, 10/25/91
    Receipt for Pompion Ale:
    Let the Pompion be beaten in a Trough and pressed as Apples. The expres-
    sed Juice is to be boiled in a Copper a considerable Time and carefully
    skimmed that there may be no Remains of the fibrous Part of the Pulp.
    After that Intention is answered let the Liquor be hopped cooled fer-
    mented &c. as Malt Beer.
    Comments:
    An anonymous recipe for pumpkin ale appeared in the papers of the
    American Philosophical Society in February, 1771. The author notes that
    he obtained this recipe from someone who claimed this tasted like malt
    ale, with only a slight "twang". After two years in the bottle, this
    twang had mellowed to an acceptable level.
    And this tidbit from The New Complete Joy of Homebrewing:
    Use cooked pumpkin and add it to a mash with active enzymes. Do not use
    canned pumpkin to which preservatives have been added. Feel free to throw in
    some pumpkin pie spices (ginger, cinnamon, allspice, nutmeg, cloves).
    I could have sworn I saw a recipe around here. Oh well. Hope this helps.
    --- VFIDO 5.52.04
    * Origin: The Black Hole BBS (1:150/370)
    Area Zymurgy, Msg#84, 22-10-92 09:32:00
    To: David Burns
    Subject: Re: pumpkin beer
    DB> about what it would taste like in a beer. Does anybody have
    DB> a good recipe for a pumpkin ale?
    6# light Dried Malt extract
    1.5 oz Mt Hood pellets
    .5 oz Tettnager pellets
    6# pumpkin
    1 Burton water slats
    1 tsp Irish moss
    .5 tsp Vanilla extract or .5 Vanill bean cut open
    1 tsp Cinnamon
    .5 tsp each Nutmeg, Allspice, Mace
    .25 tsp Clove (ground)
    Wyeast 1007 or 1214
    Peel and seed pumpkin and bake @ 350 until soft. Heat 1.5 Gal. water
    add malt, Mt Hood hops and pumpkin - boil for 30. Add salts and moss boil
    for 15 more. Add finish hops boil for 5 min. Strain cool and pitch.
    Add spices to SECONDARY. Prime .75 C corn sugar bottle and age for 3 to 4
    weeks.
    Recipe shamelessly stolen from Beer & Wine Hobby recipe of the month.
    I haven't tried this.
    ___ Blue Wave/QWK v2.10
    Area Zymurgy, Msg#81, 12-08-92 18:04:00
    To: All
    Subject: Munich dunkel recipe
    Dear Fellow Zymurgists;
    I would like to share my recipe for a Dunkel (yet to be brewed.)
    This is one of the most difficult brews to brew _properly_. Homebrewers have
    a tendency to use too much crystal in order to achieve the malty flavor and
    aroma. And roasted grains, ie. black, roasted and chocolate, should be used
    with a light hand also.
    The malty character is achieved by using quality German 2-row and by 32-34F
    lagering for at least 4 weeks.
    Munich dark (dunkel):
    5 gal OG 1050 TG 1014-1016
    7.75# Ireks (German) Pilsner 2-row malt
    1/2# Dark Ireks Crystal (60L)
    1/2# M&F (English) dark caramel (60L)
    4 oz M&F Black Patent (if domestic use only 2 oz.) 6 HBU Hall 60 min. Mash at
    152F for 1 hour Good lager W-yeast (2206) ferment at 57F Max 50F min
    For a partial mash, substitute a high quality pale unhopped malt extract,
    like Northwestern Golden, be sure it is _fresh_! (6.6#) for the Pilsner pale
    malt.
    Prosit!
    * OLX 2.2 * Cure insomia by putting hops in your pillow
    --- InterPCB 1.50
    * Origin: TRAVEL ONLINE / ST. LOUIS' #1 BBS / 314-973-4073 (1:100/635)
    SEEN-BY: 8/0 1 8 10/8 13/13 207/213 914/1001 973/1
    Area Zymurgy, Msg#87, 05-07-92 11:45:00
    To: Charles King
    Subject: Recipe request
    CK----I recently tried a few mugs of German made SPATEN dark, and immediately
    CK----fell in love with the taste. Does anyone have a recipe that CK----will
    produce a brew similar to SPATEN dark? Thanks..
    You just don't ask for too much do you?
    aroma.
    lagering for at least 4 weeks. And, of course, doing everything else right.
    4 oz M&F Black Patent (if domestic use only 2 oz.) 6 HBU Hall 60 min. Good
    lager W-yeast (2206) Mash at 152F for 1 hour
    If you was to go with a partial mash, substitute a high quality pale unhopped
    malt extract (6.6#) for the Pilsner pale malt.
    Cheers and Good Luck to ya'!
    Roy Rudebusch
    --- InterPCB 1.50
    Area Zymurgy, Msg#91, 24-08-92 06:48:00
    To: Tom Hamp
    Subject: Coffee stout
    Coffee Stout
    5 gal OG 1056
    6.6# Pale Extract
    1# Dk Crystal
    1# 2-row
    1/2# Black Patent
    8-12 HBUs for bittering
    Mash and sparge grains at 150F. Top up to 5 gal. Bring to boil add hops, boil
    30 min. Add extract, boil 10 min. For finishing add:
    1 pot good black coffee (hold the cream and sugar)
    1/2 oz Cascade pellets
    Boil two min, then chill.
    * OLX 2.2 * "You'll have a dozen doughnuts and a Coffee Stout?
    --- InterPCB 1.50
    Area Zymurgy, Msg#100, 28-08-92 18:30:42
    To: Roy Rudebusch
    Subject: Root beer
    Category 8, Topic 12
    Message 90 Sun Jun 21, 1992
    B.CAPLAN [GOODTIME Bob] at 17:41 EDT
    I was asked to add the Alcoholic Root Beer recipe from the "Winners" book.
    Here it is:
    Hi-Res Root Beer
    Wayne Waananen
    Denver, Colorado
    First Place, Herb Beer, 1987
    (extract recipe)
    Ingredients for 5 gallons
    3 pounds Munton & Fison amber dry malt extract
    2 1/5 pounds Premier hopped malt extract ssyrup
    1/2 pound crystal malt
    1/4 pound chocolate malt
    1 1/2 teaspoons Zatarain's root beer extract
    1 teaspoon Irish moss (30 minutes)
    1 ounce Cascade leaf hops (60 minutes)
    1/2 ounce Cascade leaf hops (10 minutes)
    1/2 ounce Cascade leaf hops (after boil)
    2 packages Muntona yeast
    2/3 cup dextrose to prime
    *Original specific gravity: 1.045
    *Teminal specific gravity: 1.018
    *Age when judged (since bottling): 2 months
    Brewers specifics
    Added 1/4 teaspoon root beer extract last 10 minutes of boil.
    After 10 minutes removed from heat, added last of hops and force-
    cooled with wort chiller. After reaching 90 degrees F (about 15
    minutes) sparged into carboy and pitched yeast. Racked into
    secondary at seven days. At keging added 1/4 teaspoon root beer
    extract along with dextrose.
    So there you go.... happy brewing!!!
    GOODTIME Bob
    --- Maximus 2.01wb
    * Origin: Aardvark's Aquarium -- We all live in one fishbowl. (1:283/121)
    Area Zymurgy, Msg#97, 01-09-92 10:15:06
    To: Patrick Dubois
    Subject: RE: Specialty Beers!
    Here's one form The Cat's Meow 2.
    Spiced Ale
    Source: Ken Weiss (krweiss@ucdavis.edu)
    Digest: Issue #743, 10/18/91
    Ingredients:
    7 pounds amber liquid extract (Alexanders, I think)
    2 pounds crystal malt, cracked
    1 pound chocolate malt, cracked
    2 ounces Hallertauer hops
    2 ounces Saaz hops
    4 ounces fresh ginger, grated
    2 tablespoons ground cinnamon
    1 pint starter of Wyeast American Ale yeast
    Procedure:
    Steep crystal and chocolate malt in hot, but not boiling, water for
    about 1/2 hour. Strain out grains, sparge with hot water. Add extract,
    stir until dissolved. Bring to a boil and add all the Hallertauer hops,
    the ginger and the cinnamon. Boil 1 hour. Chill the wort, transfer to
    primary, and add Saaz hops. Pitch the yeast. When the fermentation
    slows, transfer to secondary fermentor. Prime with 3/4 cup corn sugar
    and bottle when fermentation appears complete.
    Comments:
    Really nice balance of flavors. The dry-hopped Saaz blended with the
    ginger and cinnamon aroma really well, and the ginger flavor is perfect.
    The cinnamon didn't contribute much flavor, and seems to have led to a
    muddier beer than I usually get. Probably would have been better to use
    stick cinnamon instead of ground... The color is much lighter than I
    would have expected.
    Tom Jeffrey
    --- Tabby 2.2
    * Origin: COMPUSALE - New compter sale echo, Email sysop at (1:124/2118)
    Area Zymurgy, Msg#92, 02-09-92 09:02:04
    To: Kevin Doshier
    Subject: Octoberfest
    KD> Since October seems to be rolling around I wanted to try an
    >Octoberfest brew. Does anyone have a recipe that makes a good
    >Octoberfest brew?? I would reallt appreciate it!!
    According to what I read in Miller's Guide to World Beers, a
    Maerzen is a type of Oktoberfest beer. It was trditionally brewed
    in spring for consumption in fall, so I guess it's perfect.
    In that case, the Papazian recipe for Winky Dink Maerzen works
    pretty good (p. 164 in TCJOH. Here's what I used in my recipe
    and it turned out good (not too carbonated, but I think I filled
    the bottles up too much -- it's only my sixth batch. Nice creamy
    head though.):
    1.8 kg light Bierkeller malt extract
    1.3 kg WineArt light dry extract
    2.5 oz Hallertauer hops
    250 g crystal malt (0.5 lb)
    0.5 cup chocolate malt
    yeast
    1.25 cups light dry malt extract for priming
    OG 1.042
    FG 1.012
    Papazian calls for 7 lbs of Bavarian Gold malt extract, but it was
    cheaper for me to use some dry and I couldn't find Bavarian Gold
    here in Kitchener, Ontario, Canada. My amount added up to 6.84 lbs.
    I used Papazian's simple method of adding the cystal and
    chocolate malt to 6 qts of cold water in the brew kettle,
    straining most of it out after it boils and then adding the malt
    extract and 2 oz of the hops. After an hour or so, add the
    remaining hops for the last 2-5 minutes, sparge into fermenter,
    top up and pitch the yeast when it's cooled.
    No doubt some advantage might be realized by holding the mash at
    various temperatures instead of just heating steadily to boiling.
    I don't think it'd be much different with this small amount of
    grain though.
    Ends up a nice dark colour that you could adjust by reducing the
    chocolate and bumping up the crystal maybe. I brewed it June 18
    and the bottle I had yesterday was beautiful -- took about three
    weeks to get rid of its latent sweetness from the malt priming (I
    figure) and now it's very smooth and clear.
    Now I'm trying to decide which Guinness Stout recipe I should try
    from the five I have. What's a hobby without decisions?
    Andy
    * OLX 2.2 * 4 out of 5 people think the 5th is an idiot.
    --- Maximus 2.00
    * Origin: *THE K-W AMATEUR RADIO BBS-(VE3MTS)* ->HST 14.4<- (1:221/177)
    Area Zymurgy, Msg#10, 14-05-93 15:34:00
    To: All
    Subject: STALE AMBER BEER (1)
    An Eighteenth Century Beer
    No-one knows what the the brews of two centuries ago were
    like. Eighteenth century brewing practice was different from
    twentieth, or even most nineteenth century technique. To produce
    a beer that approximates those of the eighteenth century it is
    necessary to consider how the beer was made, and then try to
    guess what effect this would have. Porter, for example, would be
    unlike the modern brews of that name. It would be very strong and
    full bodied, and, as it was brewed solely with brown malt, have
    an intense caramel taste, with none of the burnt flavours
    associated with more highly coloured modern specialty malts. Most
    surprisingly, it would also have a strong, and perhaps
    intimidating, smoked flavour. I have chosen stale amber ale as my
    objective, as it is easier to imitate with modern ingredients
    than most other brews, was highly regarded in the eighteenth
    century, and, I hate smoky beers!
    Eighteenth century malts were kilned on screens over an open
    fire, with the smoke passing directly through the grain. Coke, an
    easily regulated fuel which produces very little smoke to flavour
    or colour the grain, was used for pale and amber malts. Darker
    malts were kilned over less controllable fires of straw, wood, or
    fern, which introduced smoky flavours, and if the grain was to be
    adequately dried, then it was inevitable that some of it would be
    scorched. Before the commercial production of coke began in 1680,
    all British ales were medium brown or darker in colour. Except
    for London, where massed produced porters brewed with brown malt
    dominated, most preferred the lighter malts:
    "The amber-coloured is that which is dried in a medium
    degree, between the pale and brown, as is very much in use, as
    being free from either extreme. Its colour is pleasant, its taste
    is agreeable, and its nature wholesome, which makes it preferred
    by many as the best of malts."
    Smoke flavoured beers have recently become popular with some
    homebrewers, but eighteenth century opinion was not as
    favourable:
    "Pale and amber malts dried with coke ..., obtain a more
    clean, bright, pale colour, than if dried with any other fuel,
    because there is not smoke to darken and sully their skins or
    husks, and give them an ill relish which those malts have, more
    or less, that are dried with straw, wood, or fern. The coke or
    Welsh coal also makes more true and complete malt than any other
    fuel, because its fire gives both a gentle and certain heat,
    whereby the corns in all their parts gradually dried; and
    therefore of late these malts have gained such a reputation, that
    great quantities have been consumed in most parts of the nation
    for their wholesome nature and sweet fine taste."
    "Brown malts are dried with straw, wood, and fern , the
    straw dried is best; the wood sort has a most ungrateful taste,
    and few can bear it, but the necessitous, and those that are
    accustomed to its strong smoky tang; yet it is much used in some
    of the western parts of England. The fern malt is also attended with a
    rank disagreeable taste from the smoke of this vegetable."
    All eighteenth century malts were diastasic malts - that is,
    they contained diastasic enzymes and could be mashed to produce
    sweet wort. Brewers normally used only one specific type of malt
    for each kind of beer, ale or porter. Our modern highly flavoured
    and coloured specialty malts were not possible until D. Wheeler
    invented the cylindrical drum roaster incorporating water sprays
    in 1816, which allowed the very precise roasting of malts.
    Attempts to produce malt darker than brown malt over an open fire
    resulted in a runaway reaction which reduced the malt to charcoal
    or ashes. During the nineteenth century brewers moved to more
    efficient recipes that used pale malt as a source of enzymes and
    starch, with very small additions of non-diastasic specialty
    malts and grains to adjust the colour and flavour.
    Modern brewers use a single mash followed by sparging, which
    rinses the remaining sugars from the grain. Sparging became
    normal practice only in the nineteenth century, previously
    multiple mashes were used to maximize sugar extraction. Double
    mashes were most common, but sometimes there were as many as four
    consecutive mashes of the same malt. The wort produced by each
    mash was brewed separately. The first mashes would contain most
    of the extractable sugars, the wort from the final mashes was
    used to produce small beer or ale. Much of the small beer was
    consumed by children, it was considered more wholesome than
    water. The starting gravity of the beer brewed from the main or
    first mash was typically between 1.075 and 1.110, that of the
    small ale or beer brewed from the second mash about 1.035 to
    1.055, similar to the strength of modern beer. For the
    homebrewer, malt extract makes it easy to obtain the high
    gravities required, without having to make a secondary brew to
    use up the otherwise wasted sugars. It is no longer considered
    politically correct to use children to consume the surplus small
    beer.
    The hops used in the eighteenth century were presumably low
    in bitterness, like the traditional Goldings and Fuggles strains,
    which were originally used as bittering hops as well as for
    aroma. Modern high alpha strains should be avoided. It was
    recommended that several additions of hops should be made:
    "... we advise the boiling [of] two parcels of fresh hops in
    each copper of ale-wort; and, if there were three for keeping
    beer, it would be so much the better for the taste, health of
    body, and longer preservation of the beer in a sound smooth
    condition."
    "Hops have a fine grateful bitter, which makes the drink
    easy of digestion; they also keep it from running into such
    cohesions as would make it ropy, vapid, and sour; and therefore
    are not only of great use in boiled, but in raw worts, and to
    preserve them sound till they can be put into the copper, and
    afterwards in the tun, while the drink is working."
    Up to the late nineteenth century, the word stale meant old
    and mature, and stale beer was more expensive than new beer. This
    beer was originally brewed using only amber malt; the beer's
    name refers to the type of malt used rather than the colour of
    the beer, which is darker than a modern bitter but lighter than
    most modern brown ales. Modern amber malt is intended to be used
    in small quantities to modify the colour and flavour of a brew.
    It has few diastasic properties, and cannot be used as the sole
    source of malt in a brew. It cannot be substituted for eighteenth
    century amber malt. The mixture of pale malt extract, crystal
    malt, and chocolate malt used in this recipe is an attempt to
    approximate the flavour and taste of the original malt. Additions
    such as black malt or roasted barley should be avoided as they
    would introduce anachronistic burnt flavours. This is a beer
    rather than an ale. In the eighteenth century beers were much
    more highly hopped than ales, and were usually of a higher
    gravity. Beers were more suited to long storage and being served
    stale than were ales. Before the sixteenth century, ales were
    usually not hopped at all.
    I suspect an eighteenth century brewer would find this
    recipe rather weak, more suited to being given to the scullery
    maids for breakfast than served to the high table with dinner.
    The only excuse I can offer is that we live in less heroic times.
    I used two main sources of information for this article. The
    first (1771) edition of the Encycopaedia Britannica was an
    ambitious project attempting to record the world's accumulated
    knowledge - the first volume only covers subjects beginning with
    A and B. Then the money ran out, and all other subjects were
    compressed into just two additional volumes! Fortunately, brewing
    begins with the letter B, and is covered in detail. All quotes
    are from this source. Old British Beers and How to Make Them was
    written by Dr. John Harrison and members of the Durden Park Beer
    Club after years of research and practical experimentation.
    --- TBBS v2.1/NM
    * Origin: Certa Cito BBS. Perth, Ontario. (613) 264-9093 (1:256/105)
    SEEN-BY: 8/0 1 8 10/8 13/13 207/213 910/1 915/1 970/201 973/1
    Area Zymurgy, Msg#11, 14-05-93 15:35:00
    To: All
    Subject: STALE AMBER BEER (2)
    Stale Amber Beer
    Ingredients: To brew four Imperial gallons, (or five U.S.
    gallons) with a starting gravity of 1.065, and a final gravity of
    1.015.
    7 lb. United Canadian Malt Ltd. dried pale malt extract (made
    in England)
    1 lb. Canada Malting Co. Ltd. Carastan (Crystal) malt (40 L)
    4 oz. Chocolate malt
    1 tsp. Calcium Sulphate (gypsum water treatment)
    1 tsp. Irish Moss (copper finings)
    4 oz. Willamette Hops (loose from Freshops 4.4% Alpha Acid -
    add just after the beginning of the boil)
    1 oz. Fuggles Hops (loose from Freshops - 4.2% AA - add 15
    min. from end of boil)
    1 oz. Tettnanger Hops (loose from Freshops - 5.1% AA - add at
    end of boil)
    1 pkg Wyeast 1098 liquid ale yeast culture
    Procedure:
    Crush the crystal and chocolate malt coarsely. Steep malt in
    two quarts warm (not boiling) water to which a quarter teaspoon
    of calcium sulphate has been added (this will limit the amount of
    tannin leached from the husks). After fifteen minutes, strain out
    husks and pour the resulting extract into the boiling vessel,
    along with four Imperial gallons of water, the remaining calcium
    sulphate, and the dry malt extract. Boil wort fifteen minutes and
    then add the Willamette hops. Continue to boil for ah hour and a
    half, add the Irish moss and the Fuggles hops, and then boil for
    a final fifteen minutes (total boil time is two hours). Add the
    Tettnanger hops as the heat is turned off.
    Cool wort rapidly, strain out hops and trub, aerate (stir in
    air) and then pour into a standard four imperial gallon/five U.S.
    gallon carboy with the activated yeast and enough water to fill
    carboy completely (a pail could be used as a container for the
    first stage of fermentation if you wish). Ferment in a cool dark
    place for one week - using first an overflow tube, and when
    fermentation subsides, an airlock to seal the carboy.
    Siphon beer into another identical carboy. Cooled boiled
    water should be added to ensure carboy is completely filled. Age
    at least four months before kegging or bottling. If the ale is to
    be kept for more than a year before it is consumed, an excellent
    idea if you have sufficient patience, it develops a more complex,
    vinous flavour. I am not using any priming as it will be served
    from a soda keg with minimal carbonation. If bottling you could
    add about two and a half to three ounces of demerara sugar. It
    would be a good idea to add a fresh yeast culture at the same
    time to get consistent carbonation.
    In the eighteenth century this type of beer was served in
    pewter or ceramic tankards at cellar temperature. Haze was not a
    problem. The more cautious modern brewer, who may not be able to
    control serving temperature, or is offering the beer to tacky
    drinkers who insist on being able to see what they are consuming,
    may add two tablespoons of polyclar to the secondary.
    This beer was brewed in the middle of January, 1993, and
    will be served on tap at CAMRA Ottawa's Spring Homebrew
    Competition. It will be held by the Ottawa Homebrew Committee on
    May 29, 1993, 7:00 PM at the Dempsey Community Centre, Russell
    Road, Ottawa.
    --- TBBS v2.1/NM
    Area Zymurgy, Msg#65, 27-05-93 18:52:46
    To: Kevin Mott
    Subject: English Brown Ale
    On (Tue 25 Ma) Kevin Mott wrote to All...
    KM> Does anyone out there have a good traditional English Brown Ale recipe
    KM> they
    KM> want to share? I've got Papazian's book but one of the local gurus
    KM> (brew-ru's?) said that his recipes were not representitive of the
    KM> stated
    KM> styles.
    I agree with the "local guru" of brew. Miller, however, is quite true
    to style. What follows is his extract recipe for Brown Ale (actually
    Mild):
    Ingredients:
    3.3 lbs unhopped British Malt extract syrup
    1 lb British Pale dry extract
    8 oz British Crystal Malt
    4 oz chocolate malt
    1 lb dark brown sugar (added to wort)
    6 AAUs Fuggles, Goldings, or Northern Brewer
    1 tsp Yeast nutrient
    2 Packets of Munton & Fison Yeast or 1 packet of either EDME or
    Whitbread (If you use liquid yeasts, Wyeast #1098 will give you an
    appropriate flavour profile for the style).
    (Note: there are no finishing hops in a traditional British Brown Ale.
    If you'd like finishing hops in there, I'd recommend a 1/2 oz of
    Goldings. That would make for a very light hoppy aroma, suitable to
    style.)
    JE
    --- PPoint 1.60
    * Origin: Wigan Pier, Kingston, ONT. (1:249/109.2)
    Area Zymurgy, Msg#69, 26-05-93 16:34:00
    To: Rodney Green
    Subject: ENGLISH ESB
    Rodney:
    I am glad everyone enjoyed the ESB, it sure was a hit around here. I have
    just recently brewed an American Red and an American Brown using this same
    basic recipe. They all turned out very nicely. So, I think that you will
    be able to duplicate this with the same results.
    Grain:
    Klages pale malt 7 lbs 3 oz
    Cara Pils - dextrin 1 lbs 6 oz
    Crystal 40l 15 oz
    Mash water: After adding 1 tsp. of gypsum I adjusted the pH to 5.53 and
    heated to 170 degrees. I added approximately 11 quarts of water to the
    grist.
    Mash: Strike temperature was 154 degrees and a pH of 5.19. Mash time - 2
    hours.
    Sparge: Sparge water pH was adjusted to 5.45 and heated to 180 degrees in
    order to achieve a final sparge strike temp. of 170 degrees and grain was
    sparged for 45 min.
    Boil: I added 1 tsp of gypsum at the beginning and 1 tsp of irish moss at
    30 before the end. Total boil time was 75 minutes.
    Hops: Willamette 4.3 alpha - 2 oz at 60 minutes(before end)
    Willamette 4.3 alpha - 1 oz at 15 min
    Tettnanger 4.2 alpha(whole) - 1 oz at End
    Yeast: Chico 1056 Wyeast in a starter. I have had just as good of luck, if
    not better, with 1028 London ale yeast in a starter.
    Original gravity:1.049 pH:4.96 Terminal gravity:1.013 pH:4.48
    Fermentation: In soda keg - 10 days - 60 degrees.
    After fermentation: One week at 32-34 degrees
    Filter: Beer was filtered through a .5 micron absolute cartridge type
    filter.
    Carbonation: Chilled beer (32-34 degrees) was put under 10psi and rocked
    200+ times.
    All strike temps are critical but start temps should be adjusted to your
    brewing methods.
    After initial blow-off period I closed the keg and periodically let out CO2
    to maintain 13-14psi. When temp was dropped to 32-34 I would periodically
    add CO2 to maintain 10psi. Be carefull, if you do not let the CO2 out often
    enough then you will over carbonate the beer. I did that once and had to
    reattach the blow-off tube.
    If I have forgotten anything, please post me a note.
    BTW: I got the ribbon and score sheets - thanks. Did you say something
    about a mug?
    Good brewing.
    KT
    þ VbReader V1.3 þOk, now for a quick backuÇAÑ&ý#^1sð
    --- TMail v1.31.2
    * Origin: The Nashville Exchange * 24 Lines * 615-383-0727 (1:116/19)
    Area Zymurgy, Msg#70, 03-06-93 19:47:16
    To: All
    Subject: Melomel Recipe (LONG)
    Hello All!
    I found this in a mead lovers digest archive from Internet. I thought you
    might be interested.
    Date: Wed, 7 Oct 92 13:53:37 EDT
    Subject: plum melomel recipe (long)
    I've gotten a few requests to post this recipe. I've added some of my
    process also to give you an idea of my mead making. As you read this
    you'll see that I make a product which is alot like wine.
    Some general comments about the recipe. If you want the end product
    to be sweeter you can add more honey. But do not get the original
    gravity above 1.100 or you will have problems with stuck fermentation
    or sluggish fermentation. You can add an much as 50lbs of plums if
    you want this to be _really_ plummy. Relative to original gravity,
    the higher the gravity the longer the product will need to bottle age.
    I use acid blend to balance out the end product. This is strickly a
    personal preference. If you really want to get into it and check the
    SO2 levels there are test kits available for that, this will ensure
    that you have the right amount of sulfites for the end product you are
    making.
    Having made these statements here is my recipe for Plum Melomel.
    Enjoy!
    Plum Melomel
    To make: 5 gallons
    7.5lbs Citrus Honey (Orange Blossom is the best or whatever )
    (honey you like to use )
    25-30lbs Plums (halved and pitted is best, but at least halved)
    (if you can freeze them for a couple of weeks )
    (before you use them you'll get a better juice )
    (yield because freezing breaks down the cell )
    (walls )
    3-4 tsp. Yeast Nutrient
    1 pkg Pectic Enzyme
    1 pkg Champagne Yeast
    Acid Blend (you'll need an Acid Testing Kit to )
    (determine how much to add. amounts )
    (depend greatly on the plums )
    The Day Before:
    Start the yeast by boiling 1.5cup of orange juice with 1.5 cup of
    water. Take it off the heat and add 1 tsp of yeast nutrient. Cool
    the mixture. When cool put into a sulfited bottle add the yeast and
    agitate occasionally over the next 24 hours.
    The Day of:
    Make sure the plums are at room temp do not heat them to do
    this, just let them come up to room temp naturally. Dissolve the
    honey in 2 gallons of water, do not let it boil, just get the water
    hot enough to dissolve the honey. Combine the plums, honey water,
    yeast nutrient, pectic enzyme and 2 more gallons of water in a large
    open primary fermenter. Mix well and take a gravity reading add water
    until the gravity reading is between 1.080 and 1.090.(I believe 1
    pint of water will drop 1 gallon of must 0.010, I can't remember
    exactly) Once the gravity is correct add the yeast stir it up cover
    lightly. Stir the fruit down twice a day, once in the AM and once in
    the PM.
    Some Days Later:
    Check the gravity after about 5 days. When the gravity reaches 1.020,
    rack and press the must into a sulfited glass secondary fermenter and
    add 1/2 camdon('sp) tablet per gallon of must to prevent oxidation. If the
    fermenter is not full to within 1/2" of the lip use sulfited marbles
    to make up the difference. Fit a fermentation lock on the bottle and
    let it rip.
    When the gravity reaches 1.000 rack again into a clean sulfited carboy
    again adding 1/2 camdon('sp) tablet per gallon for the same reason. Again
    if the mead does not come within 1/2" of the lip use sulfited marbles
    to make up the difference. Test the acid level at this point using
    your handy dandy acid testing kit and adjust the acid to a level of
    .55. The kit will tell you given what your acid level is at how much
    to add.
    When the fermentation stops, let it sit for a few days to let the lees
    settle out. Rack into a clean sulfited carboy adding 1 camdon('sp) tablet
    per gallon of product and fine with a Bentonite mixture. Let this sit
    for 10 days. Rack the final product (leaving the lees behind as
    usual) into a clean sulfited carboy and let bulk age for three months.
    If you have a spare frig you can put the carboy in, the last month of
    the bulk age put the mead in the frig to chill proof it.
    Bottling:
    If you are lucky enough to have a wine filter. Filter the mead with
    fine filters and bottle. Let bottle age for at least 6 months (1 year
    is better). Enjoy.
    Roger Locniskar Boston Technology Inc.
    <loc@bostech.com> Wakefield, MA 01880
    Regards,
    Luke
    --- FMail 0.94
    * Origin: To see the point, is to miss it completely (3:635/563)
    Area Zymurgy, Msg#73, 04-06-93 23:36:02
    To: All
    Subject: Cloning Sierra Nevada Pale Ale...
    Hello All!
    Most of us here dont have access to the Home Brewing Digesr of
    Internet. While it was agreed some time ago, that it would be too costly to
    feed all of the HBD into this echo, I feel sorry for those who cant get to
    it. Therefore, I hope you dont mind if I "snip" the best articles from the
    HBD,
    and repost them here for all to see. I dont want to do this is people are
    going to start flames about it, etc. That would end up worse than the
    benefits.
    But if no one objects, I cant see any problems involved! All feedback
    welcomed!
    Date: Wed, 26 May 1993 10:12:20 -0500 (CDT)
    Subject: snpa revisited
    Here is some info and speculation on Sierra Nevada Pale Ale and how
    one might try to clone it. SNPA is surely worth emulating, yet it
    has an elegance of flavor that is a bit elusive. I can't claim to
    have cloned it, but am iterating toward it!
    Note that Sierra Nevada Draught Ale is SG 1.048 while Sierra Nevada
    Pale Ale (bottled) is SG 1.052. The Draught also tastes a bit
    sweeter to me than the bottled.
    Malts used are U.S. 2-row, dextrin malt (U.S. cara-pils), and
    crystal malt. I don't know the proportions used at Chico, but it
    seems to me that you shouldn't be too heavy-handed with the crystal
    malt, as I don't find a pronounced caramel flavor in SNPA, in
    contrast to, say, Mendocino's Red Tail Ale.
    Hops are Perle for bittering and Cascade for flavor/aroma. Perles
    are a fine general-purpose medium-alpha bittering hop, while
    Cascades are signature hops in SNPA, Liberty Ale, and other
    American pale ales.
    Yeast is Wyeast "American" ale or bottle-cultured SNPA.
    An all-grain recipe for a 5-gallon batch goes as follows (your
    mileage may vary):
    8 pounds U.S. 2-row pale malt
    1 pound U.S. cara-pils
    0.5 pounds crystal malt 80L
    0.8 ounces Perle (alpha 6.5) at 60 minutes
    0.5 ounces Cascade (alpha 6.3) at 30 minutes
    0.5 ounces Cascade (alpha 6.3) at 2 minutes
    0.5 ounces Cascade final addition (see below)
    yeast is Chico yeast
    In the mash, aim for a starch conversion temperature of 153 - 155
    degrees F for some residual sweetness in the beer. As for the hop
    schedule, factors such as hop freshness and vigor of boil will
    affect the final beer. To my palate, SNPA is a medium-bitter beer,
    not high-bitter beer, so something like 35 IBUs seems to be a good
    target.
    Regarding that final hop addition, I believe that Chico runs the
    hot wort through a hopback with some fresh hops in it, so you might
    rig up a homebrewer's gadget equivalent of a hopback. Or, you
    might add the final addition at flame off and let the hot wort sit
    for 10 minutes with the lid on before chilling. Or, you might try
    dry-hopping. I'm not claiming that these will produce an
    equivalent effect, but they are all attempts to give the beer some
    of the requisite hop flavor and aroma.
    Hope it lead to some enlightenment...
    Regards,
    Luke
    --- FMail 0.94
    Area Zymurgy, Msg#73, 10-06-93 11:00:36
    To: All
    Subject: Smithwick type
    This is a nice pale ale that closely resembles Smithwicks :-)
    Crystal malt 500 g
    Caramel malt 200 g
    Chocolate malt 100 g
    Flaked barley 120 g
    Goldings LEAF hops 1 3/4 oz Boil
    East Kent Golding LEAF hops 1/2 oz finishing
    Burton Water Salts 20 g (for Kingston water)
    Munton and Fison Unhopped Light Malt Extract 3 kg
    Andovin super nutrient 2 tsp
    Yeast Lab liquid yeast (A05) Irish Ale.
    OR WYeast (1338) European Ale.
    Munton and Fison Light Dry malt 2 cups (for priming bottles)
    Lightly crush malt grains and add to 15 liters of water. Add flaked barley
    and bring to boil. Strain out grains and barley. Add Boiling hops and boil
    for 40 min. and remove. Add finishing hops and boil for 10 min. and remove.
    Move to fermenting pail and add water to the 23 liter mark and pitch yeast
    when temp is 20 C. HINT - A NYLON GRAIN BAG AND HOP BAGS COME IN HANDY.
    O.G. 1.045
    Enjoy and Cheers !
    --- Maximus 2.01wb
    * Origin: From Beyond the Event Horizon (613-353-6495) (1:249/109)
    Area Zymurgy, Msg#51, 10-06-93 23:19:00
    To: All
    Subject: stout recipe
    For those of you collecting recipes...I offer this:
    Mark's Oatmeal Butterscotch Chewies
    Ingredients:
    6 lbs Great Western 2 row
    1 lb Munich Malt 10L
    1 lb Vienna
    1 lb Crystal 80L
    1/2 lb Chocolate Malt
    3/4 lb Roasted Barley
    1/4 lb Black Patent
    4 lbs Pale Malt Extract
    1 inch licorice
    1 1/2 lb Quaker Old Fashion Oats
    1 cup Mild Molasses
    1 lb Brown Sugar
    2 oz Galena Hops (pellets) @12.8%
    Wyeast 1084 Irish Ale
    1/2 cup Corn Sugar for priming
    Procedure:
    I used a David Miller style mash, using a strike temperature of
    136F and immediately raising to 156F for the starch rest. At 45
    minutes, the mash passed the iodine test (GW is a fast converter). All
    grains and Oatmeal were mashed together. Oatmeal makes for a slow
    sparge. I did the mash with 3 gallons of water and sparged with six. I
    ended up with 6 gallons of wort. This was a bit much, as I was aiming
    for five. The problem was that I failed to take into account the 4 lbs
    of extract (not really a problem :-}). Next time I will cut the sparge
    to 5 gallons. I brewed for 75 minutes, the hops, extract, molasses,
    brown sugar, and licorice were added at the 60 minute mark.
    Comments:
    I bottled this one just a week ago, and it tastes excellent. In
    fact, it was smooth at bottling. I have never had a stout taste so good
    so young! Must be the Oatmeal. It cleanly coats the throat. No
    excessive bitterness, or burned flavor. Lots of flavor, but very well
    balanced.
    Warning:
    For novice brewers (I still consider myself novice), I have a
    few words of advice. When brewing with Oatmeal, or at least this
    recipe, use a full size 1 1/4" blow-off hose. The oatmeal makes for a
    very foamy blow-off while the high gravity and Wyeast 1084 creates a lot
    of energy.
    Specifics:
    Original Gravity: 1.084 (6 gallons)
    Final Gravity: 1.023 (about 8% alc by vol)
    Primary Ferment: 8 days
    --- RAMail 3.2
    * Origin: Missing Bit II (619) 442-4875 (1:202/111)
    Area Zymurgy, Msg#73, 10-06-93 11:37:00
    To: Tony Laughton
    Subject: Oktoberfest - Recipe Ideas
    Hello Tony!
    This might answer your question a bit easier.
    Date: Wed, 2 Jun 1993 14:04:09 -0500 (CDT)
    Subject: oktoberfest recipe ideas
    Most German Oktoberfest beers have a starting gravity of 1.052 -
    1.055, which puts them more in line with the AHA "Vienna" style.
    These beers are amber-colored (aim for 10L - 12L), malt-accented
    lagers. From the point of view of recipe formulation, you have the
    choice of using crystal malts, munich malt, or some combination.
    In their book, George and Laurie Fix present recipes using crystal
    malt. Depending on your setup and extract efficiency, for a 5-
    gallon brew you might use a grain bill such as the following:
    8 - 9 pounds pilsner malt
    6 oz crystal malt 10L
    6 oz crystal malt 60L
    6 oz crystal malt 120L
    The above grain bill specifies pilsner malt, and you should use the
    finest German or Belgian pilsner malt. Lacking that, use a good
    U.S. 2-row pale malt. The crystal malt blend gives the beer the
    requisite color, body, and sweetness.
    In subsequent articles and postings to HBD, George Fix has reported
    using mixes of DeWolf-Cosyns Cara-Vienne (20L) and Cara-Munich
    (80L) malts. In the first issue of Brewing Techniques, it appears
    that George Fix has settled on a mix of Cara-Vienne and Special B.
    Using the BRF program, the following grain bill should produce a
    color in the desired range:
    1 pound Cara-Vienne (20L)
    1.5 ounces Special B
    As an alternative to the above grain bills, one could explore the
    use of Munich malt, which should give color and malt flavor. As an
    example, consider the following grain bill:
    5 pounds pilsner malt
    4 pounds Munich malt
    1/4 pound crystal malt 40L
    Note the high fraction of Munich malt in the grain bill. As U.S.
    Munich malt can be of variable quality, brewers have raised the
    concern that the resulting beer will suffer from grain harshness.
    However, with the availability of DeWolf-Cosyns Munich malt, as
    well as German Munich malts, surely such a recipe should be tried.
    For hops, use fine European Noble hops, and hop to 22 - 25 IBUs (or
    roughly 6 AAUs). As an example, the hop schedule might be:
    0.85 ounces Tettnang (alpha=4.5) at 45 minutes until end of boil
    1/2 ounce Styrian Goldings (alpha=4.9) at 30 minutes until end of
    boil
    1/2 ounce Saaz (alpha=3) at 15 minutes until end of boil
    This style is not a bitter style, so total hopping is kept down.
    Nor are pronounced hop flavor or aroma desired, so the last hopping
    is 15 minutes before end of boil.
    Use a good lager yeast and proper fermentation temperatures.
    Wyeast "Bavarian" lager works very well. Ferment at 50 degrees F
    or so. Rack the beer to secondary, and lager for 4 to 8 weeks.
    Regards,
    Luke
    --- FMail 0.94
    Area Zymurgy, Msg#67, 13-06-93 12:33:52
    To: All
    Subject: Honey Lager
    Hi, All
    I thought I'd send out an update on the Honey Lager I started March 22.
    I let it lager in the basement 2 months, racked it 3 times then bottled.
    The temp down there at the start was about 45 F, and it gradually
    warmed to about 55 F before I bottled.
    The recipe was : 10 lbs light malt extract
    4 lbs Clover honey
    1 oz Cascade hops
    1 Pk Wyeast American Lager Yeast
    Yeast Nutrients
    O.G. was 1.08
    F.G. is 1.008
    Est. Alcohol 10 % (and it feels like it too) 0 0
    This has only been in the bottle for 3 weeks and it already tastes
    incredible and has a GREAT head of foam, especially if poured too fast !
    Anyway, this was my first experiment with honey, and now I know it
    won't be the last...maybe a strwberry Melomel next...Sounds yummy !
    L8R and Great Brewing to All.
    --- Maximus 2.01wb
    * Origin: P A S C A L A L L E Y (1:343/52)
    Shorty.
    Forty minutes closer to the hills in a house the bank is kind enough to let me live in
    Best advice I got was to ditch the yeast that brew kits come with and use the appropriate Safale yeast that is happiest working the the ambient temps you have. There are heaps of varieties that all have their own happy temperatures. Go chat to the local brewing supplies place and grill the owner for info.
    Also, don't be affraid to chuck in some extra hops, try roasted malts etc.
    I brew in stubbies so we don't drink so much. Just started again last week after a break from brewing for four or so years. Got a stout on the bubble at the moment...
    My farther in Law Jack Faber who lives in Laidley (queensland) has writen a book about a year ago on Home brew.He is after all the queensland Home brew champion for the last 5 years running. Make a stonking brew and love going to see them as we are always sat up the shed drink beer all day
    95 300 Tdi Defender 90
    99 300 Tdi Defender 110
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
    Ellendale Tasmania.
    Mate stick with the kits first up, that brewing from scratch is too time consuming and very hit and miss if not an expert, that's where all the bad stories come from about home brew.
    Only thing to remember with the kits is, clean everything, once you've mastered the bottling thing, investigate kegging your brew, this is the best way to do home brew it's less time consuming as there is no bottling involved and from the time you start your brew to your first drink is about 9 days
    Bottling will take 4 weeks.
    Next time your go to the local home brew shop ask him about kegging, you won't go back to bottling, it is expensive first up but once your setup it's really worth it.
    Baz.
    Cheers Baz.
    2007 BMW R1200GS
    Williams West Aust
    Hi Easo
    As others have said,cleanliness is the go.
    Get the pink steri,much more user friendly,the metabisulphate isnt very nice,can taste taint your brew and kill your yeast if not rinsed thoroughly.
    Yeast,get Safale(blue packet) for warm weather brewing,it will emulsify the dregs,you will end up with a jelly cake in the bottom of your fermenter,makes for a clearer brew.In winter if you can get the temp low use saflager(yellow pack).Both should be in a fridge at the local homebrew shop.
    KEGGING.Start saving for a kit asap,I should have got mine many years ago.$350 to $400 for 2 kegs,regulator,hoses,beer tap(get the pluto beergun,much better)and connects.You will need to get a bottle of foodgrade C02 from BOC,my E size(about 2 feet tall) lasts around 2 years.Depending on how greedy your mates are,you will need to get at least 1 more keg to age the beer better.Out of the keg,its drinkable after 2 days out of the fermenter!!!! but better aged.
    You will soon get sick of bottles,steralising them,trying not getting the dregs stired up,then there is the explosion risk if you over sugar or bottle before the brew is finished.I used plastic coke bottles,1.25l are good pour a middy the rest goes into a jug and put it in the freezer.New lids available from homebrew shops.
    All the best
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Sunny Pucka
    Cheers lads, Im off to a good start then. I'll post when the first batch is ready for testing
    Williams West Aust
    I just opened a keg of Brewcraft Mexican Cerveza(corona) with a dry enzime sachet(enables more sugars to be consumed by the yeast,gives a dryer flavour and a tad more alcahol),coopers brew sugar 2 and safale yeast.Beautiful drop!!!!
    Guy at the brewshop is getting into low carb beer as he is as big as me.His tip is 750gm Diatose instead of sugar and the dry enzime,alcahol is a bit lower but better for you as its low carb.May try a brew or 2 myself.
    Andrew
