Results 1 to 10 of 17
Thread: Ball Joint modification
    I have spent some time trying to get rid of the dreaded rear end clunk on my Defender. Slack in the diff seemed acceptable and there was very little play anywhere else in the drivetrain. First step was replace the worn A frame ball joint, but that didn't seem to solve the problem so I replaced all the rear suspension bushes and bolts.
    The problem was actually the replacement ball joint, but I've solved the problem and the Defender is clunk free for the first time since I bought it 5 months and 25,000km ago.
    The replacement ball joint looked like a good design with the top screwed down to adjust for wear, but the material and workmanship didn't look all that flash. I went ahead and fitted it and it now appears that it failed almost immediately.
    The thread for the big screw at the top stripped, so while I thought I had a nice new tight ball joint, what I actually had was huge amounts of play.
    I discovered the problem while fitting the new bushes, so I modified it and appear to have solved the problem and still have the ability to adjust it when it wears.
    I fitted a plate to hold the top bit in place. It is bolted in using the existing holes. The holes weren't threaded all the way through, so I had to use a tap to extend the thread. I fiitted a nut under the plate and tightened it against the ball joint fitting to stop it working loose. I reckon it is a better design than the original. It's still adjustable, but shouldn't fall apart.
    I don't know if I was just unlucky to get a ball joint made by the work experience kid in some Taiwanese factory, but the thread looked pretty sloppy even before I fitted it.
    May 2002
    Sydney, Australia
    NICE job, I'm lazy - I would have just bought the Maxi Drive one!!!
    LRH
    Disco 4 SDV6 Auto
    Disco 4 SDV8 Dual Cab Project
    Disco 2 M57 Extra Cab Project
    Foton Tunland Cummins ISF
    Disco 1 3 door 4.6 V8 Auto
    RRC V8 Auto "Classic" Softdash
    RRC 300 TDI Auto
    Disco 1 TD5 Auto Buggy
    Disco 1 300 Tdi Auto Ute
    SAME Explorer 70HP 4x4 Tractor plus Nell Loader
    Subaru GDA WRX
    Triumph Bonneville SE
    Yamaha TTR250
    Quote Originally Posted by LRHybrid100 View Post
    NICE job, I'm lazy - I would have just bought the Maxi Drive one!!!LRH
    I could have just replied, "I'm tight - I repaired the old one", but I did it mainly because I needed the vehicle back on the road immediately.
    Pennant Hills, Sydney
    the money you saved can now be spent on other things and even better
    it worked
    disco seriesII mods so far:-bullbar,hyd winch,
    detriot locker,lsd front,C.D.L kit,chipped and bigger intercooler,2" lift,rock sliders, lsd in transfer case, modified auto trans.
    In the event of nuclear war,Disregard this message
    South Yundreup,WA.
    What is the maxi drive unit worth??
    2011 Discovery 4 TDV6
    2009 DRZ400E Suzuki
    2003 WK Holden Statesman
    Departed
    98 Ducati 900SS Gone & Missed
    Facta Non Verba
    May 2002
    Sydney, Australia
    About $165 from Graeme Cooper
    Disco 4 SDV6 Auto
    RRC 300 TDI Auto
    Subaru GDA WRX
    Yamaha TTR250
    or....
    Andrew
    1998 Landrover Defender 300Tdi 130 HCPU Expedition
    1972 Peugeot 504 Sedan - Daily Driver
    Moruya Heads/Sth. Coast, NSW
    Quote Originally Posted by vnx205 View Post
    Allan, nice to see a fellow South Coaster on the Forum, I live at Moruya Heads.
    I am interested in what you have done with the ball joint, did you buy it from Land Rover, seems very poorly made (balljoint), does the original have that groove across the adjusting screw, do you place spacers on top of the adj. screw to get play out, has the nut completely stripped, if so does the top plate you added seal in the grease, does it have a grease nipple, cant see in the photos, good job, Regards Frank.
    Quote Originally Posted by Tank View Post
    The ball joint came from Four Wheel Drives in Melbourne. I have bought quite a few parts from them since 1983 and this is the only item that was of very disappointing quality.
    The one I took off, which I guess was the original one was not adjustable.
    The thread was stripped enough that I could lift the screw out with my fingers.
    I didn't need spacers because I adjusted the preload on the ball joint with the two bolts that went through the top plate. I can screw the top plate down a bit more later if it wears. The locknuts stop it moving.
    I thought about a grease nipple, but was a bit pushed for time. I probably should have added one. However, there is a very thin O-ring at the bottom of the adjusting screw, so that should keep in the grease that is already there. I smeared some silicone around the top of the big screw to try to keep water, dust and mud out of the ball joint.
    NSW SW Slopes
    Sorry to be playing the devil's advocate, but is it legal to modify a suspension part? The 2 bolts normally just hold the ball joint to stop it falling out, but now the bolts are load-bearing at the top, although if they come adrift then the ball can only push through a small distance before the diff bracket pushes onto the A-frame, so you end-up with the rear-end floating around a little. I expect it would fail a reg check if spotted.
