Results 1 to 2 of 2
Thread: Frame Sliders for D90
    Here's something, Discowhite, for your D90:
    The Rock Ware Defender 90 Frame Sliders both protect the Defender 90's frame and prevent the frame ears from catching on ledges and obstacles. The Frame Sliders are constructed from 3/16" steel and will handle substantial abuse without deformation. The design allows the slider to extend past the rear trailing arm ears to provide a smooth transition at this pesky hang up point. The Defender 90 Frame Sliders mount to the Defender 90 using existing, factory bolts. No drilling or other vehicle butchery is required for a proper installation. Fit Defender 90 only, and do not fit Defender 110, Range Rover Classic, or Disco1.
    Padstow NSW
    i was gonna make something simmilar to that for the disco, only got hung up on the rear mounts once, just ask ferno and harry!
    think its a bit of over kill for even a standard 90, heck my chassis is 440mm off the ground with the t arm mounts only 40mm lower.
    but i spose if i get bored one day and there is metal to use?? who knows
    cheers phil
