Results 1 to 9 of 9
Thread: wife's p38
    Ferntree Gully VIC
    wife's p38
    having a problem with the wife's drivers door
    when the door is closed the display screen beeps and tells you the door is open
    any suggestions on what it could be ???
    or a easy fix for it ???
    cheers all
    130's rule
    Christchurch NZ
    Quote Originally Posted by hiline View Post
    cheers all
    Replace it with a Defender.
    1995 Defender 110 300TDI :D
    1954 86" Series 1 Automatic :eek:
    Ex '66 109" flat deck, '82 109" 3 door, '89 110 CSW V8, '74 Range Rover, '66 88" soft top, '78 88" soft top, '95 Disco ES V8, '88 Surf, '90 Surf, '84 V8 Surf, '91 Vitara.
    Ferntree Gully VIC
    Quote Originally Posted by jimbo110 View Post
    I already have a 130TD5
    130's rule
    Kyabram, VIC 3620
    cheers all
    Ray - they are normally connected through the door light switches, on the front pillar near the hindges, but some have a seperate switch in the same location (ie two switches)
    They are normally held onto the pillar with one self tapping screw, and they get a bit dirty and the earth connection ends up being bad.
    Unscrew the switch, it will just pop out of the pillar, clean it and the metal behind the switch, get a new self tapper and screw it back in.
    Try that first.
    Also check that the wire is still attached to the end of the switch
    Christchurch NZ
    Yeah, i mean to have two!
    Christchurch NZ
    Quote Originally Posted by ladas View Post
    Try that first.
    hmmmm, a bad earth, who would have guessed!
    Ferntree Gully VIC
    Try that first.
    thanks mate
    i'll give that ago tomorrow
    130's rule
    Ray, it is more than likely the door ajar switch.
    Have a look at http://www.rangerovers.net/forum/index.php and search on door ajar (make sure you search on all terms) in the P38A forum
    The switch is in the door latch. Possibly very corroded. See this thread for pic http://www.rangerovers.net/forum/viewtopic.php't=3870
    Ron
    Ferntree Gully VIC
    Ron
    cheers ron
    130's rule
