Results 1 to 10 of 27
Thread: central locking kits for 95 Defender
    May 2006
    Redesdale, Victoria
    Hello all.....
    just wondering if anyone from the brains trust can help me. I bought some c/l actuators for my defender and found they won't fit the front doors. i asked the Tint professor if they can fit a central locking kit and was told yes, but for a heft price. So my question is, has anyone fitted C/l to their older defender and, if yes, how hard was it and how much did it cost.
    Pm me the answers if you like...
    Thanks in advance
    Chris aka THB
    I fitted central locking to my pre-Defender 110 using one of the generic kits. Took a bit of ingenuity, but no real problems. The doors are different from the Defender, but I see no reason why this would present a problem, although I am not familiar with the inside works of the Defender doors.
    In my doors the actuators are low down in the doors and with long rods to connect to the locking plungers.
    May 2006
    Redesdale, Victoria
    My problem i foundd is the window, when wound all of the way down, would foul the actuator.....
    hmmmmmm
    Quote Originally Posted by haggisbasher View Post
    hmmmmmm
    The window does not go all the way to the bottom of the door, and also, as it goes down it gets closer to the outside - I can't remember which effect I took advantage of (and I am not going to pull the lining off to have a look), but I do remember that it was a fairly tight fit, but was possible.
    Melbourne, Vic
    Check out Defender200tdi gallery... he's got a gallery where he's installed the C/L kit in his wagon. I've done it in my '99 td5 using a generic kit (based upon Defender200tdi's install), not hard, just requires a bit of bending/zip-ties etc!
    Current: ‘16 Disco Sport (7seater) aka « Family Bus 2 »
    Sadly Gone: '77 RRC 2 Door aka "Beast"
    Gone: '92 RRC Vogue SE aka "The Family Bus"
    Long Gone: '99 Td5 Defender aka "The TANK!"
    Bexley NSW - Sydney
    where / how did you run the wires into the doors ?
    Did you do a tidy job with some protecting tube for the wires ? or just left them out hanging!
    May 2006
    Redesdale, Victoria
    i have hunted all over for Def220tdi galery....dya have any hints for where it is?.......
    'feeling very lost'
    Bexley NSW - Sydney
    'feeling very lost'
    I did the same, no find ? Link anyone ?
    Melbourne, Vic
    From door-pillar, I just ran from the gap between the frame and trim into the side of the dash.
    Covering: I did mine just wrapping in electrical tape, but Defender200Tdi used some tubing that came with his kit.
    Sorry about not being able to find Defender200Tdi's gallery, I'm 100% sure there used to be one. I've got the shortcut at home, I'll see if the gallery is still there. I may have the pictures stored somewhere too...
    Maybe PM Defender200Tdi too for pics...
    Defender200Tdi Guest
    Quote Originally Posted by Cameron_Def View Post
    That was in my gallery on the old site, but I've never been able to find all the images since the new site started. Were they ever archived anywhere?
    Paul
