Results 1 to 10 of 12
Thread: Ultrasonic alarm sensor in Disco 2
    Melbourne VIC - Australia's largest Nanny State. Thanks Brumby!
    Hi
    I have just added a ultrasonic sensor to my D2. Some cars I have seen have two, however I have installed just the one over the passengers head.
    Does the stealer need to use testbook etc. to tell the alarm computer to now use the ultrasonic sensor? I couldn't get the alarm to go off just by waving/ making noise etc in front of the ultrasonic sensor.
    Kyabram, VIC 3620
    Quote Originally Posted by cwebb View Post
    Hi
    Where did you wire the sensor to?
    Quote Originally Posted by ladas View Post
    It has to be wired to somewhere! ??
    Ron
    Kyabram, VIC 3620
    Ron
    Yes, there are connectors on each sensor (front and back) four connections on each, one earth, the other three wire back to the BCU in parallel
    When I installed the ultrasonic sensor, I removed the 'blanking' plate. Then it was a matter to just feel around a little bit and lo and behold I found the necessary wire loom to connect to the sensor.
    Cheers Chris
    Kyabram, VIC 3620
    Cheers Chris
    Okay - then they might not function unless both are fitted - from the wiring - they are connected in parallel.
    You might want to check the body control unit - which should be behind the LH side facia - for the connector C0063 to see if the connections/wires into pins 6 (white/black wire) and pin 8 (slate/purple wire)
    There are 12 pins on the connector.
    Doreen, Melbourne
    cwebb,
    Where did you source the ultrasonics and may I ask how much $$
    '01 D2 V8 4.6 Auto 7 Seater ACE
    Town Car - '11 Ford Mondeo Titanium TDCi -
    LROCV Member
    It was an ebay item, cost around $20.
    Since I did not have any form of interior protection for the alarm, I thought I'd give it a go.
    I know its correct since the wiring is compatible.
    Williams West Aust
    I thought they were standard.
    Mine PEE me off bigtime!!!!
    Black Disco,you cant leave the windows open at all,not even a tad.The alarm goes off if its windy!!!!
    Pain in th bum,but dont really wish to get rid of it.JUSTINCASE!!!!
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Doreen, Melbourne
    Would be good if you could isolate the ultrasonics for when you would like to leave the windows open. Might have a read of the RAVE CD...
    LROCV Member
