Results 1 to 9 of 9
Thread: quickie
    Apr 2002
    Bellara 4507
    32.43 MB
    quickie
    anyone know the diameter of the rubber seals that go in the the battery box on a defender....?
    dont you hate it when you leave your notes at home :P
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    May 2006
    Townsville, QLD
    Nah but I've got a couple. I'll go n have a look
    May 2006
    Townsville, QLD
    38.16 OD Groove is 3.2 Deep so minor Dia should be about 32.16
    Apr 2002
    Bellara 4507
    32.43 MB
    thanks mate
    May 2006
    Townsville, QLD
    Your welcome They were a little loose in mine when I did the 2nd battery. I used a bead of sicaflex to secure them once I was happy.
    Cheeers
    May 2003
    On The Road
    this fender is certainly keeping you on the hop Inc,,
    Apr 2002
    Bellara 4507
    32.43 MB
    they all do when i first get them :P
    am waiting on wheel hub grease seals so i can get the front hubs back on..
    so it is sitting on axle stands, and i have to have it rolling again for the 27th so i can get the gearbox fixed...
    i have the air cleaner and induction tubing out as well so i can get to the back of the motor and the heater hoses so i can try and work out a way to fit and shield a glind shower heater in there somewhere.....
    and i need to adjust the tappets as well as plug all the holes in the thing to try and get it as waterproof as fenders can get
    plus trying to sort the battery box so i can fit dual batteries and a traxide sc40 battery controller and a 100amp alternator....and work out why the crap the main power lead goes thru the cabin and out to the started motor via the firewall and work out where it normally goes... also have to find out what the relays in the battery box do ...
    fit my gps, fit a uhf, fit spotties and the list goes on.....
    Quote Originally Posted by incisor View Post
    Good oh, when you find out what the relays do could you tell me. Also could you tell me what value the row of four fuses are? My number two fuse has melted all the plastic and I'm not too keen to mess with it until I know what it is and does.
    Simon.
    May 2006
    Townsville, QLD
    Quote Originally Posted by abaddonxi View Post
    Simon.
    I believe these are for your air con. I'll have a look at mine when I get it back from JC tomorrow arvo.
