Results 1 to 10 of 23
Thread: Oil Consumption
    May 2006
    Townsville, QLD
    Unhappy Oil Consumption
    G'day All
    Question for the 300TDi owners. What is your engine oil consumption like?
    Is it nothing between changes (assuming that changes are at 5000 k intervals)
    Half a litre, per 5000 k, A litre per 5000 k or more?????
    Mine has 41,000 K on the clock (allegedly) and I did an oil change @ 40,000. Its now done 41,800 and I've just added half a litre. I'm dead sure it was spot on when I refilled it and the only leak I know of is the cooling hoses are weeping slightly at the oil pump. I'm a bit sus of the Turbo bearings recently as its started to make an unusual sound which is like a secondary turbo sound. Lower in frequency but runs up at about the same time that the boost comes on.
    Your thoughts please.
    Brisbane- Southside
    Hi Stevo,
    .........using 5K changes as a bench-mark, these are my own observations, covering ALL types of driving.
    Mineral, or semi-synthetic oils,:
    usually needed around 3-500mls top up anywhere approaching the 3-4000k mark.....so fairly normal.
    FULL-Synthetic oils :
    ( have tried various in a few vehicles) ...Father currently using mobil 1 ( diesel ) 10-40 i think....zero oil usage.
    Engine approaching 128k...or there abouts.
    Hope this helps,
    Pug
    May 2006
    Townsville, QLD
    Come on you 300 TDi owners
    I need your 10 cents worth PlEEEEEEEEzzzzzzzzzzzzzzzzEEE
    I got my Defender back in Oct 06. Had 79,000 on the clock and now has nearly 83,000. In that time I have had to put about 2L of oil in it as it blew the seal on the oil filter (previous owner had OVER tightened filter) and also the oil pressure switch started to leak and was replaced. Since I've fixed those (about 2,000km ago) it hasn't used any oil.
    I'm going to do an oil change in the next month. Oil that is in it is HPR Penrite.
    Oct 2006
    Boisdale, Victoria
    oil use
    300,000 km, 10,000 km/6 months change intervals only ever used Castrol GTD/GTX diesel 15w40, check oils at least once a week. 800 ml - 1 ltr between changes
    Braidwood, NSW
    Mine's done 300000km now, and it uses so little oil between services (every 10000km) that I don't bother to check. On a recent trip up north (13000km) it didn't use a drop even though it was over 40 degrees in the shade every day and it worked bloody hard (fully loaded, low range territory, deep mud for long periods, etc).
    Norm
    Norm
    2011 D4 TDV6 (Audrey)
    99 Defender 130 single cab ute 300Tdi (Mabel)
    99 S1 Disco Tdi (Grumble)
    -ex 97 S1 Disco V8i (Beast)
    -ex 94 Defender Tdi (Antichrist II)
    -ex 98 S1 Disco Tdi
    -ex 78 Strangie (The Bucket)
    I've owned 1998 300tdi since 55,000kms (now has 127,000kms) and I change oil every 5,000kms. I add about 500mls in that 5000km interval. Not sure exactly how much I add, but I always have to add a little bit in 5,000kms.
    Has been like this since I've owned it so I assume it's normal.
    Pete
    May 2006
    Townsville, QLD
    Thanks Guys
    Keep em coming. I'm beginning to think I under filled it. Its spot on now so we will see where we are at 45000.
    Apr 2002
    Bellara 4507
    32.43 MB
    my 95 disco tdi uses about 200-300ml per 5000k at 230,000 klms on caltex delo 400.
    if your diesel engine isnt using oil then it is making it, and you need to get an oil test done to see just how much the diesel is affecting your oil.
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Melbourne, outer South East
    I concur with the others . a few hundred ml between changes. I probably lose half of that through my leaking rear main oil seal.
    Check that the wading plugs are removed from the bell housing ( if a manual ) and the timing belt cover. If not, and you do have a leaky seal ,oil could be building up inside there.
