Results 1 to 10 of 22
Thread: The Shame
    Ringwood, Vic
    Red face The Shame
    I will start with "Forgive me".
    I went to the Watagans with some Toyo friends on the weekend and have brought embarrassment on the landy name.
    We went with 2 Discos and 6 Toyos,
    First, an over enthusiatic water entry left my beloved V8 silent in the middle of the water trap I have been told the pic of my stranded Landy will be sent to 4WD Monthly by my Toyo mates ( I did drive out after restarting).
    Then both Discos got hung up (and had to be rescued by the LC80) in a spot where the Prado waltzed through
    The Prado did die after exiting with excessive water consumption. And the LC100 blew his front diff and was trucked home, but no photos as it was 2hr wait for the towie (I know, I should have waited for the photo opportunity)
    Be gone, thou useless creature. Foul not this forum again!
    Ron
    Fairfield VIC
    Wow, thats got to be unlucky doing that in ankle deep water
    Quote Originally Posted by mns488 View Post
    The first time I ever went 4WDing with my brother-in-law (diesel GQ Patrol) and his brother (diesel Jackaroo), I went through a similar puddle and killed the ignition on my '86 Rangie. Oh the embarrassment - and the ribbing I got for ages afterwards.
    A new set of ignition leads after the event fixed that problem. It never occurred again.
    At least I recovered some cred when the Rangie powered up a rocky hill with no problems but the GQ took several attempts and the Jack even more. Oh, they were also impressed by the RR's articulation, so much so they took photos.
    Ron
    Ringwood, Vic
    It was one of those holes you drop into and then climb out of, we were nearly out when she gave up You can see how the back is lower in the water than the front.
    It has new leads (8mm) and new everything ignition wise, just really dirty now.
    The TDi Disco had no problems with it. The second hole was deeper, above the bottom of the door, and with a better entry I had no probs, just got snagged on the diffs. It was mainly the embarrasment of a stock Prado out doing both Disco's in this hole that bites. 3 recoveries for the day, 2 for me and one for the other disco.
    Taller tyres and some trimming in order I think
    Feb 2006
    gosford
    Quote Originally Posted by Discobunny View Post
    Mate at least you were out having a go. I did nothing but sit on my bum most of Easter.
    By the sound of things it was not only Landies in trouble, the LC 100 did it's front diff as you said.
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    for your penance, you shall visit TOYOTAHEAVEN 5 times a day for a week.
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Adelaide Hills - SA
    That's a bummer. Didn't realise that Prados were so good, I always slag them off as being SoftRoaders.
    Better get that V8 waterproofed.
    DiscoDave Guest
    Don't forget the Prado has LSD in the rear which gives it an advantage (unless you've got lockers)... You still should have beat it!
    McDisco Guest
    Discobunny
    Your not alone mate...I headed up to the Big Desert, Border Track and Little Desert only to stuff my serperntine belt, idler pulley and harmonic balancer on the highway coming back! Travelled the rest of the distance on the back of a tow truck! Got really good consumption though! lol
    Angus
