Results 1 to 8 of 8
Thread: Has anyone run a TD5 out of fuel?
    Ok, I've read in the manual that there is a procedure for re-priming everything.
    My question is, has anyone actually run one out of fuel? Did you manage to get it re-started ok?
    Alex Heads
    Quote Originally Posted by Captain_Rightfoot View Post
    I have run out twice. First time about 18mths ago, no worries, procedure as per handbook. My fault.
    Last time not long ago. Mate 'drove it dry', then cranked the battery dead. Result - one shagged fuel pump $1000 bill, Not happy Jan.
    http://www.aulro.com/afvb/showthread...ight=fuel+pump
    Quote Originally Posted by FenianEel View Post
    Hmmm... that's kind of comforting
    Adelaide Hills - SA
    Yep - ran out 2 or 3 times. It takes 2 or 3 minutes of Ignition on, wait, ignition off, ignition on, wait, etc for the fuel pump to cycle through and purge all the air. Then with a bit of cranking she starts up again. Lots of black smoke for a few seconds and then good as gold.
    Hope I haven't damaged the fuel pump 'cause that's an expensive one to replace.
    Apr 2007
    Northern Hunter Valley,Dungog Shire
    Yes, I have, and the procedure in the manual worked perfectly.130man.
    Ballajura, Perth, WA
    Well in my book he is only a mate if forked the $1000 for the damage he did, if he simply handed you back the vehicle and let you pay the $1000 yourself he ain't a mate he is **** pure and simple
    Ferntree Gully VIC
    Quote Originally Posted by cartm58 View Post
    not the kind of mate i'd call a mate
    if that was the case
    130's rule
    Alex Heads
    Hmm, well, yes, mate
    Mate has many meanings and uses in Australia
    i.e. F**k off MATE!
    Oi! mate - don't do that or I'll smash ya
    etc,etc....
    He is a decent bloke and has done a fair bit for us, so I wasn't too hard....I know he will come through with some $ too
    Or I'll cut his jacobs off
