Thread: Peeling windscreen stickers
    Anyone use something sticky to re-attach the corners? Got a couple peeling. Just renewed my Desert Parks Pass, and the sticker ain't gunna last 12 months..
    Yes I should clean the glass even better beforehand, but there must be something I can apply.
    I'll pass on the superglue suggestions I forsee though.
    TIA & regards
    Max P
    If you can peel the sticker off attach it too the windscreen with double sided tape, I had to do it with NPWS a few years ago, rangers never said anything about it.
    Corindhap, VIC
    Why don't you cut a piece of clear contact a bit bigger than the sticker and stick that over it?
    Kyabram, VIC 3620
    Quote Originally Posted by Tusker View Post
    TIA & regards
    Max P
    Yes a thin layer of woodworkers PVA glue.........dries clear.
    It's not just cleaning the glass, you also must get all the air bubbles out.
    As for the peeling sticker, you'll probably find its going brittle as well and is shrinking. The only thing I can suggest is some clear contact sheet (like you get to cover books) and place over the back of it.
    Have you tried contacting Desert Parks to get a replacement sticker?
