Thread: Multi login on adsl.
    St Helena,Melbourne
    4.28 MB
    I have 2 pc's setup at home, 1 upstairs and 1 downstairs, both with their own modems. When i login with 1 the other disconnects ? how do i enable them to login at the same time ? I have logged into the modems config browsers and used the same login/ password on each.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    you cant do it that way....
    only one digital device can be logged in at once on a single line as a general rule
    you need a modem router or modem wireless router
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Perth, WA
    You can't have two ADSL modems sharing a single ADSL/telephone line (Which I presume is what you're describing?) as each would be trying to sync to the equipment back at the exchange. I'm kind of suprised they both even sit connected to the same line without the second one causing issues to the working one......never tried to do this though.
    The usual way to do this is to use a modem/router to connect to the ADSL line and then connect the PC's to it by ethernet, USB or wireless depending on location and what equipment/cabling you have in place.
    You could use one PC and it's modem to then re-share the connection to the other (Again depending on what kit you have available) but this is far less reliable IME, needs the first PC left on for the second to connect to the Internet, and you also need cabling between the PC's rather than to/from the router, which gives you more flexibility.
    Jeff
    1994 300TDi Defender
    2010 TDV8 RRS
    Have a read of this I'm not even going to attempt to say it better than he does
    http://www.ozcableguy.com/broadband.html#3.1
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by incisor View Post
    I have a wireless router/ modem in one which is upstairs so i can use the laptop, so i need to run lan cable dowstairs to run the other one ? Damn thats a pain in the a.se, i have 3 spare adsl modems i cant use
    1974 VW Kombi bus
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    buy a wireless lan card for the one downstairs... $40 odd bucks and your done
    Perth, WA
    If you have a wireless modem/router, I'm guessing this is standalone? If so, you just need this plugged into a phone socket which is hopefully near at least one PC, and then use wireless for the other one? Unless your house is big, or has internal brick walls, you should get a wireless signal that far, but it may take some playing about with the position of the router...
    Jeff
    2010 TDV8 RRS
