Thread: Coming to Australia- Bluey's Rebuild Part 3
    Dubbo,NSW
    Hi everyone,
    well the chassis rebuild is all but finished, just the fuel return pipe to fit and a couple of clips on the intercooler pipes. I've still got the aux. fuel and water tanks to fit but those will have to wait until the body tub is refitted.
    Since my last post I've fitted a new set of copper brake pipes from Automec which although not cheap were very good quality. These went on along with extended flexi hoses by Goodrich. That is hopefully everything sorted with the brakes as I rebuilt all of the calipers with new pistons seals and discs whilst I was still running Bluey. Props have been cleaned up and greased and diff pinion seals have been replaced. The oil seal behind the handbrake was also replaced as it was leaking and the hand brake was obviously cleaned up at the same time. The drive train was now complete and full of oil. All of the oils will be replaced after a short running time to make sure any shotblast in the axles etc. is flushed out.
    The radiator assembly took a little bit of fettling as the upgraded intercooler has slightly wider reservoirs top and bottom so the frame had to be bent open a little to accomodate it. The silicone and stainless steel intercooler pipes were then fitted and look great!
    The stainless steel sports exhaust from Twisted Performance was fitted next and the thing is a work of art. It consists of five sections each joined to the next by a very snug fitting swaged joint. I dare say they would be gas tight even without the stainless pipe clips, unfortunately the photos don't do it justice. The exhaust, intercooler, intercooler pipes and K&N air filter cost us £1050 but I've been impressed with the quality of all of it, I just can't wait to see how it all affects the performance of the 200Tdi once Charles has tweaked the engine settings.
    Once all of the steering rods were refitted along with a new steering damper my old Southdown Engineering Steering and Axle guards were fitted along with a couple of JATE rings so the front end is now nicely armoured up. Once I get the aux. fuel tank fitted I'll be getting a main fuel tank guard from Southdown, which the nice man said he would modify to protect the linking fuel pipe between the two tanks. Southdown Engineering, I believe, supply the guards which are fitted to SAS Land Rovers so they are very well made.
    The next job on the list is to partially strip the bulkhead (don't want to disturb the wiring too much!) to get it ready for painting. Once the bulkhead is refitted I can see if I can get the engine running again!
    After that its just a simple job of refitting bodywork, grafting in twin battery electrics, fitting a decent stereo, fitting storage boxes, twin spare wheel carriers........... blimey its never ending!
    SIII 88" Petrol 1978
    SIII 88" Diesel 1977
    90 2.5 Diesel 1986
    GS 101" Modified 1979
    Range Rover Vogue SE 1990
    I now drive!? 1994 200Tdi 110
    80" 1950
    thats one hell of a lot of work going on there, definatly better than new.
    you will have to park it over mirrors to appreciate it all.
    and how sad it will be the first day it gets mud on it.
    fantastic.
    Safe Travels
    harry
    Yass NSW
    The way it's coming along it is worthy of a show car!
    Should warn of nudity on this post.....let the girl get some clothes on
    nice rig must be fun throwing all the $$$$$ at it
    Love the stainless IC pipes how much $$ and where..I want em please
    Adelaide Hills - SA
    I like that SS exhaust as well. Looks fantastic. Have you calculated how much money you've put into it (or would that be unwise)?
    Quote Originally Posted by DirtyDawg View Post
    Yes, more info please!
    Looks great!
    Dubbo,NSW
    Coming to Ausralia - Bluey's Rebuild Part 3
    Hi everyone,
    thanks for your encouraging words.
    The engine upgrades fitted were :-
    Stainless steel sports exhaust
    Silicone and Stainless steel intercooler pipes
    Intercooler
    K&N air filter
    All of the bits were bought from Twisted Performance. As I obviously fitted these myself, Charles (Mr Twisted Performance), let me have the lot for £1050. This price includes him tuning the engine once I get Bluey back in one bit.
    There's quite a few companies selling turbo upgrades but Twisted Performance had the advantage of only being 20-30 miles away. Also my mate had already had one of their intercooler upgrades fitted to his 300Tdi Disco and it made one heck of a difference!
    The quality of all of the stuff is excellent with stainless steel pipe clips being used as well. His web address is www.twistedperformance.co.uk , he's also had a few articles in the usual Land Rover mags.
    Regarding the cost of the rebuild Rosy and I want to build ourselves an overland vehicle for around £15,000. The budget used to be for £15,000 but now I'm more thinking around that figure!! The base vehicle cost us £4,995 which leaves us with £10,000 to rebuild and fit out the vehicle.
    I know that we must be close to spending that already, however most of the big bits of kit have already been bought. Stuff still left to get include new set of six tyres, split charge system, twin batteries, cabin soundproofing, decent stereo and GPS. We read an article in one of the Land Rover mags about a bloke who had built a "budget" ie cheap overland Landy for £18,000 so our expenditure doesn't look too bad so far.
    We are both fully committed to the rebuild and the trip so to tell you the truth as long as we both get a Land Rover that we are both proud of and will get us to Australia we don't really care about how much it will cost in the end. When its finished I'll add it all up and tell you!
    Talk to you later
    Andy
    90 2.5 Diesel 1986
    80" 1950
    Bundaberg Qld.
    Looks great. Are you going to go overland most of the way here?
    A question: what is the advantage of copper brake lines? As far as I knew they are illegal on vehicles here in Australia. Not sure why though.
    WR.
    84' 120" ute - 3.9 isuzu.
    Adelaide Hills - SA
    Are you coming out here just for the drive, or are you emigrating?
    Have you got a route sorted yet? Pakistan/India or Middle East/Africa?
    Dubbo,NSW
    Hi everyone,
    I'm emigrating to Australia but Rosy is just returning home! Rosy has been in England for six years now and has had enough of our rubbish weather. Soon after we got together she took me over to Oz for a look and I loved it so she suggested we live in Oz and you know the rest!
    The route which we are planning for is around Europe then down through Turkey, Iran, Pakistan then India. We will then probably ship Bluey to Australia. I would like to enter Australia at Perth then spend some time crossing over to Dubbo NSW where we intend to settle. We're settling in Dubbo because that's where her brother lives just in case you were wondering!
    Copper brake pipes were used as they are corrosion proof and are alot easier to work than steel brake lines. When I was dismantling Bluey both brake lines to the front axle were heavily corroded where they lie along the top of the chassis. Both lines crumbled when I tried to remove them. The line which runs to the rear axle had already been replaced with a copper one at some time.
    90 2.5 Diesel 1986
    80" 1950
