Thread: how to install maps in tomtom on PDA?
    Hi
    I have installed TomTom 5.x onto a PDA.
    When I try to run the software it says I have no map installed, or something like that.
    I have a folder with a map of Australia that suits TomTom but dont know which folder to copy it to on the PDA.
    Anyone know?
    hi there teh maps will go onto teh root directory of your (storage) card in a folder named australia then it should find it ok
    Steve , Perth is easy there is South of the river and North of the river..... and three ways to get across
    Oct 2003
    Gold Coast, Qld.
    couldn't say for sure... had a similar problem myself when installing on my phone... couldn't find maps... took them off and on again a couple times then all of a sudden it could see them.
    I think one key though is don't take off the guam maps first... you need to swap maps from guam to australia within the program... then you can delete the guam ones.
    I think maybe remove everything tomtom off the pda first and do a clean install and start from scratch
    RAAF Tactical 200184 & 200168
    Quote Originally Posted by worraps View Post
    Thanks for that I'll try it tonight
    Quote Originally Posted by DirtyDawg View Post
    Yer I know it's those damn tricky river crossings that get me every time
    St Helena,Melbourne
    4.28 MB
    Maps need to be on the sd card in a folder named australia-map.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    so I shouldn't be installing either to the internal memory? only on the card?
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by HangOver View Post
    The maps are about 73mb so they wont fit, depending on Ipaq model the most mem will be 32-64mb.
    1974 VW Kombi bus
    I have a Palm Treo, I just checked your right not enough on board memory
    In case it happens to anyone else:
    I upgraded to tomto6 re-installed tomtom & maps onto the SD card.
    Tomtom is in a folder in the root called: tomtom
    the maps are in a folder called: australia-map
    the voices, cool hay it talkes to me :-) are in a folder called: voices
    all works fine once I found the right com port on the PDA to talk to the reciever.
    thanks for the advice
