Results 1 to 10 of 16
Thread: Tow plugs - how many types are there?
    here
    I had a quick look at my tow plug today and it looked different to the standard round plug I am used to seeing. It was only a quick look so I may be wrong but are there different types/formats of round tow plugs? I am fairly sure it had Land Rover printed on the outer plastics..
    Orange NSW
    There are normally only two types of round plug a six pin and a seven pin unless this is some kind of specialised one.
    The norm these days is seven pin in line as aposed to round.
    Steve.
    theres 5 (but you'll generally only see #2+3)
    1. 5 pin round, 4 spots around a central earth ,rare these days
    2. 6 pin round 5 posts around the central earth, common
    3. 7 pin round 6 pins round the central earth with the pins spaced around so that there could be another pin at the bottom, common
    4. 7 pin round as above but with all the outside pins spaced evenly. only seen a few.
    5. the big 7 pin one that trucks use that occasionally makes it onto the landy.
    Wazza Guest
    Mine has a 7 pin Large
    Ruslan Guest
    Mine is "flat", all pins in line. Have to use adaptor ($10 from K-Mart) to connect to other end.
    Ruslan
    There's more.
    5 and 6 pin small round
    5 and 7 pin large round
    7 and 12 pin flat
    Dunno about now but years ago, the type of plug depended on the State in which it was used.
    The big round was quite common in some States. I've got a brand new old stock socket in the garage.
    See here: http://www.narva.com.au/Trailer_1.html
    Williams West Aust
    The new standard is the flat type.
    Eastern staters,unsure which ones run a much bigger dia plug than us,its a dead give away to the origins of a vehicle when you see the plug!!!
    Was 5 or 6 pin over here,grew to 7,but not as big as dia plug as others use.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Queensland
    Hi catch-22, here’s the pin outs for both the 7 pin Round and Flat trailer connectors.
    Cheers.
    Kyabram, VIC 3620
    I assume by the term "clearance lights" - it means side / rear / tail lights.
    Cheers.
    dannydesch Guest
    need conversion?
    Hi guys,
    can I jump in with a question?
    I will be renting a trailer in a few weeks and I have round pins (Disco 3). How do I know if I need to buy a conversion before I rock up at the place? I see many cars here in Canberra with the flat plugs.
    Also. the guy at the garage told me I needed to change the fuses as I would blow them, he said. Amy of this true?
