Results 1 to 10 of 21
Thread: oziexplorer ce on pda
    Apr 2007
    Perth Western Australia
    I have just picked up a hp rx5700, it has tom tom 6 loaded,and I would like to move the 250k topo maps and the hema maps from my laptop to the pda. Does any of my knowledgable collegues know the best way to do it. I apparently have to buy ozi ce and that is all I know. After many years of the hard way, I now ask first. Cheers guys
    Bayswater, Melbourne
    I have oziexplorer ce running on a Toshiba pda. You can use the trial version to play with and see if you are happy with it. It works ok but shuts down after an hour (or maybe 15 minutes, cant remember) You will need to copy the maps onto a compact flash card or SD card.
    Personaly I prefer paper maps but sometimes it is good to be able to see exactly where you are on the map by checking the pda.
    Ian
    Ozi CE is the way to go....
    but you will need the pc version of ozi to setup the maps on, Fortunately you dont need the registed versoin, just Ozi to make up the .map files and the file converter if your maps arent in a native ozi standard (like .ecw)
    May 2002
    Heathcote (in "The Shire")
    Don't know what processor the HP has but to use .ecw files the pda needs an ARM processor.
    Martyn
    Apr 2007
    The Auslig topos are ecw files I think, so how do you compress them to run on the pda, or will they run in standard form.
    Apr 2007
    The other thing is the topos are in mosaic format will this be a problem?
    Cheers Guys
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by 97discotdi View Post
    Cheers Guys
    go to the gpsautralia.net forum and check out the maps section, i got the whole of vic/nsw on dvd that i compressed and fit onto a 2 gig sd card for my pda, they were indexed and ready to rock. I used IMG2ozf that i got from the Ozi webiste to convert and compress the maps for pda use and just right clicked and sent to my sd card in a card reader.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Apr 2007
    Thanks Guys, I will give it a go
    I experimented with Ozi-CE on a PDA. I found it easy to use, but found the following limitations :
    1. The PDA would reset if not used for a couple of weeks and then Ozi would have to be reloaded.
    2. I was able to see where exactly I was on a track, but if I wanted to know where that track went to, or intersected with others, by the time I zoomed out enough to view the wider field, everything was so tiny I couldn't make out tracks. It should really be used in conjunction with a paper map.
    3. CE versions of maps take up a lot more memory than PC versions.
    Because of these limitations, I've gone to a small laptop/tablet, which has performed really well in the bush.
    Upwey, VIC
    Quote Originally Posted by Numpty's Missus View Post
    Damned annoying that little trait. If you load the program into the part of the memory that DOESN"T get lost when the battery runs flat, then it won't operate.
    We have this problem all the time. The PDA's are designed to be in use all the time, but we only use ours for trips away. Seems a waste of electrickery to have it plugged in all the time but thats the only way to avoid the problem
    You can get another program that you can backup everything to another SD card, so when you pull the PDA out of the cupboard charge it up, put the SD card in restore everything, and then put in your maps card and away you go.
