Thread: Routine clutch job
    rightback_atchya Guest
    Routine clutch job
    Hello, How much can I expect to pay for a routine clutch job for a 96 LR Disco TDi? My clutch feels like it has 1000km of city driving left on it.
    Is it a job I could do on my own with an engine jack? (How replaced clutches on non-4wds) Is it a good idea to change anything else while the bell housing is off? Slave cylinder?
    Thanks for any feedback.
    if youve done it on a car you can do it in a rover, everythings just a little bit bigger and you have a front prop shaft to catch your arms on...
    the usual check everything you can get your eyes ino while your there applies, search the forum for threads based around your gearbox and your engine and that will point you in the right direction....
    The clutch slave is a doddle to get in and out anyways so if you dont do it its not a biggie to do later..
    what makes you think that you only have 1000km left in the cutch?
    drive in drive out all parts supplied and paying attention to due maintenance I'll open at $1.5k for an engine out clutch change...(thats not mates rates either)
    NSW far north coast
    get a complete clutch kit. JustinC has done heap of these in the recent past and is currently recommending the AP kit over the Valeo (too many Valeo kits have been shuddering) This includes the cover, plate and thrust bearing.
    Replace the spigot bearing (soak this in warm engine oil before hand, don't use grease) I'd recommend getting the flywheel refaced, even if it looks ok, just as a precaution. The flywheel bolts will be a bitch to get off (they use something like Loctite 272, which I use to put everything back together.)
    Also replace the fork (check the current clutch fork thread), slipper pads, staples, and clutch rod retainer clip. Use a good quality moly fortified grease on the pivots and splines (sparingly)
    Depending on total km, rear main seal may be a good idea. If you do it, do not use any oil on the shaft, don't use a gasket, use only good quality RTV silicone and be careful with the installation tool.
    Gearbox input shaft seal is easy, no tricks except that the seal housing also supports the layshaft front bearing cone, so don't drop it.
    Get a manual so you have all the bolt/nut tension specs and procedures.
    NSW far north coast
    BTW, did this three weeks ago and took out the gearbox/t/case to do it as I needed to replace the t/case input shaft seal and intermediate shaft O rings.
    I cheated and used a mates pit, made it much easier.
    Whoa! $1500.. and I thought manuals were cheap to repair. Getting my hands bruised and doing this myself just got considerably more appealing.
    Thank you for your advice. It's appreciated.
    I have checked on the clutch fork thread. Pressed metal? - that must be less than 2mm thick, not what you'd expect to be used in non-sporting machinery generating anything over 100Nm...
    Cheers.
    NSW far north coast
    $15-1600 is the going rate for Patrol or Land Cruiser clutches around here.
    Quote Originally Posted by rightback_atchya View Post
    Cheers.
    They are, Try getting an auto repaired....
    2mm thick clutch fork Yeah the metal might be but its also shaped, so its stronger than it looks and what of that Ive seen throw out forks in that design on some of the cheaper trucks, they make more torque than what a rover does... The fork is pretty much immaterial to how much power the clutch can shift that comes down to the pressure plate and friction plates.
