Thread: disco 2000 ecu chipping...
    Denmark WA
    Hi everyone...
    Was wondering what ecu upgrades I can choose from for a late 2000 disco (auto)? I have read the newer models have a "flashable" ecu (put on a trenchcoat and take it to the park? ) but my earlier one isn't? True? I notice Tombraiders upgrade is not for mine?
    I have also read of higher exhaust temps warping manifolds, but I found my manifold warped already... and busted studs... (and cracked head)so maybe this is a landrover issue not a chip issue?
    Thanks for any advice!
    tombraider Guest
    You are correct.
    The Earlier ECUs require a solder in replacement of the main chip.
    I'm endevouring to offer this on an exchange ECU basis as de-soldering/re-soldering a PLC44 chip is excruciating on the eyes
    Problem is trying to get hold of good ECUs at decent price to do the work to. (I'm a sole trader and only do it outside my 'normal' job)
    In the interim I'd suggest contacting Triumph Rover Spares for 'hard soldered' ECU upgrades.
    As for warped manifolds/busted studs....
    This is a product of the manifolds design.
    The manifold is webbed and when it heats up the manifold cannot move on the head and bends or breaks studs. It happens to standard TD5s particularly those used to tow and in higher ambient temperatures or in hill terrain where they run warmer.
    Chipping does increase EGTs under load but only marginally... More fuel = more heat... (The secrets in controlling it to safe limits)
    The solution is a 2 part job. You'll need a die grinder.
    Grind the webbing from between the ports leaving the main manifold.
    Then slot the stud holes on either end of the manifold a little. This gives the manifold room to expand/contract as it heats up.
    These modifications will avoid the common issues.
    Denmark WA
    Few questions...
    When you say "slotted" what do you mean?Cut through from the outside in or "elongate" the hole so it has some lateral movement?
    And a further ecu question... Will these chips just "drop in" or is there a requirement for testbook to be used?
    Thanks,
    tombraider Guest
    Quote Originally Posted by davros View Post
    Thanks,
    Elongate horizontally....
    As for the chip question... I'll confirm this soon....
    However, exchange ECU's will require testbook or equiv.....
    I am looking at a "supply chip and decoder" option which will allow customers to attend their own Electronics guy and have the socket fitted to the ECU, then you can just plug in and drive away....
    Perth, WA
    Quote Originally Posted by tombraider View Post
    I saw a chip upgrade on an older TD5 Defender back in the UK which used an extra box in between the loom and the ECU rather than resoldering and replacing the chip in the ECU. Other than convenience, is there any advantage to either approach?
    Jeff
    1994 300TDi Defender
    2010 TDV8 RRS
    Doreen, Melbourne
    You are correct.
    So could you estimate approximate man hours it would take to grind, slot & refit, just so i can get an idea of how much I would be up for. Don't have the skill to do ones self.
    Thanks.
    '01 D2 V8 4.6 Auto 7 Seater ACE
    Town Car - '11 Ford Mondeo Titanium TDCi -
    LROCV Member
    Denmark WA
    Supply chip and decoder
    ...interested in that... let me know of any updates!Pretty handy with a soldering iron myself - well enough to get me in trouble!
    Dave.
