11th July 2007, 10:19 AM
ignition live behind 95 fender dash
Have finished wiring up the low level alarm for the fender using a rangie float sensor.
where would be the best place to get some +ve ignition live only (not accessory) behind the dash of a 95 fender.
I promise I will get the wiring diagrams for this truck soon.
regards
Steve
11th July 2007, 10:27 AM
Directly from the ingnition switch. Just use a test light as you turn the key and you will soon find the wire you need.
You may want to put an inline fuse there aswell to protect you alarm.
