Results 1 to 10 of 31
Thread: Stripped Sump ... What to do..
    Bexley NSW - Sydney
    I went to replace the oil in my Defender (TD5) today, and found I must have been in a hurry or something last time and stripped the sump thread..
    Seeing its Alu, I can not weld on a new nut, so I can see i have two options
    A. Helicoil
    B. Second hand sump
    C. A Champaign Cork
    Anyone got any other suggestions ?
    Also, what thread size is the sump bolt ?
    Everytime I go to give my baby something, it comes around and kicks me ... she really does not like TLC !
    Thanks in advance, I hate seeing my Defender bleeding in the backyard ...
    Bexley NSW - Sydney
    No one got any suggestions ?
    NSW far north coast
    Helicoil.
    Best things out for aluminium.
    helicoil.
    repco sell things called recoil, same thing different name.
    aluminium lesson- don't pull too hard on the spanner,
    but you knew that already!!
    second hand sump as a last resort. see hoe you go with re threading it and follow the directions, it's not too hard.
    Safe Travels
    harry
    Bexley NSW - Sydney
    Thanks guys,
    How about the thread size ?
    Does anyone know what size I should get ?
    Apr 2007
    I am lost
    go the champagne cork means every time you change your oil you gotta drink another bottle or 2
    Yass NSW
    Sorry can't remember. I know that buying a sump bolt from Land Rover is $34. I had specialty fastners find me a replacement after I dumped the oil all over the super cheap car park. Mate towed me round to have a bolt measured up to replace the sump bolt I had just lost.
    Yinnar South, Vic
    I'd be removing it to rethread it and loc tighting the helicoil in
    Kingston, Tassie, OZ.
    Quote Originally Posted by rovercare View Post
    Yeah, and while you're there, remove and locktite the oil pump bolt
    JC
    Apr 2007
    I am lost
    sorry mate i have looked through all my td5 engine spec books/catalagoue and can't find the sump bolt diameter ,i can find the torque wrench setting for tighnening up a sump drain bolt 15lb/ft
