Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
Thread: Headlight Wiring Upgrade Kits
    Queensland
    Hi folks, it about time I posted some details about the headlight wiring upgrade kits I have.
    There are a number of advantages to doing a headlight wiring upgrade.
    An upgrade can not only get around the problem of having dull lights but as it takes the current load off the existing headlight switch which usually means that you will never have to replace the switch again and a headlight wiring upgrade kit is usually heaps cheaper than the cost of replacing a headlight switch.
    Not only does a headlight wiring upgrade usually make your existing headlights brighter than they were but in the future, if you decide you want to fit more powerful globes to brighten up your headlights even further, you already have the heavier wiring in place so you will get the most advantage out of the new globes.
    You don’t need any electrical expertise to fit the upgrade but it is not a Plug-&-Play installation. You will have run all the wires and the kit has everything you need to fit it, all the wire is colour coded and the instruction will take you through the installation step by step based on the different wire colours.
    We also supply a special plug that plugs into one of your existing headlight loom’s headlight sockets. This plug removes the need for you having to try and work out which wire does what, it’s all done automatically for you.
    The Headlight Wiring Upgrade Kit is a generic kit designed to upgrade the headlight wiring in most vehicles and I also have a Combo Kit which up grades the headlight wiring and also provides the additional wiring to upgrade the wiring for two driving lights.
    My kit’s headlight wiring is the same size wire that other driving light kits use for the driving lights, and my kit uses even heavier wire in the Combo kit for the driving lights wiring.
    As I posted above, these two kits are generic and will fit most vehicles but because Defenders have their battery under the Passenger seat, I make two Supplementary kits which are added to the Headlight Wiring Upgrade Kit and the Combo Kit to accommodate the installation of these kits in a Defender.
    I offer all these kits at special prices to AULRO members and the prices, which include postage, are listed below.
    Headlight Wiring Upgrade Kit $130-oo + postage ( AULRO member's price $130-oo, including postage ).
    The Defender Headlight Wiring Upgrade Kit kit is $150-oo + postage ( AULRO member's price $145-oo, including postage )
    Combo Headlight / Driving Light Wiring Upgrade Kit $170-oo + postage ( AULRO member's price $165-oo, including postage )
    The Defender Combo Headlight / Driving Light Wiring Upgrade Kit $199-oo + postage ( AULRO member's price $190-oo, including postage )
    I’ll post some pictures and more details in the next few days and you can phone me on 07 5569 2557 or PM me to order the kits.
    There is now info on my web site at Headlight Wiring Upgrade Kits
    Cheers, drivesafe.
    Oct 2003
    Montrose, Vic.
    I have no business affiliation with Drivesafe or Traxide...... just a very satisfied customer.
    6 months ago I fitted one of these kits - anyone considering it may want to read this thread - including before and after pics:
    http://www.aulro.com/afvb/showthread...ight=headlight
    Money really well spent I'd say....
    Thanks again Tim.
    Mark
    Mark
    2003 D2a TD5...gone...
    2000 D2 V8...gone...
    https://bymark.photography
    St Helena,Melbourne
    4.28 MB
    I ordered a combo kit of Tim a few days ago so look forward to fitting it and the IPF's i scored off an AULRO forumite, should make my night drive to Adelaide next week a bit brighter - i just hope it arrives in time.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Perth, WA
    Just out of interest, on a Defender, can you take the power feed from the alternator to save running back to the seat box with the power wires?
    My thinking is while the engine is running, you'll get full alternator voltage (I'm fittign HID's as well), and when off, you should still get battery voltage over the alternator charge cable for things like dim-dip (Assuming 1994 Aus cars have that, as I've never bothered checking!)
    Jeff
    1994 300TDi Defender
    2010 TDV8 RRS
    Mar 2007
    South Arm, Tasmania
    Quote Originally Posted by jik22 View Post
    I've always been told that this is not a good idea Jeff. While you will get the voltage at the alternator (output is usually around 14V) it's the amperage that you want to power lights. I'm not really sure of the exact reasoning, but ab auto sparky told me that it is always better to power accessories directly from the battery. I'm running HID's (Hella Predators) on the Disco and about to install a Hi/Lo HID conversion kit in the headlights, and taking all power sources from the battery. Admittedly, this is easy in the Disco with the battery sitting just behind the right headlight.
    Cheers .........
    BMKAL
    Quote Originally Posted by BMKal View Post
    The alternator provides all the current you use while the engine is running anyway, so your reasoning does not make sense. Your sparky was talking about the advantage of not overloading existing wiring, but in fact for accessories that are normally run only when the engine is running, such as headlights, since the current they use comes from the alternator, it is better to have the current taking the shortest route (and hence minimum voltage drop) direct from the alternator rather than from the alternator at the front of the vehicle then back to the battery and forward again to the headlights next to the alternator.
    For the Disco with the battery at the front there will be no significant difference, but for a Defender with the battery under the seat the difference in voltage will make a significant improvement to the brightness of the Q-H lights, although I doubt it will make any difference to the HID lights, as I suspect they are designed to give the same light output regardless of voltage (within reason).
    In any well designed electrical system, however, the wiring size will be large enough and the connector quality good enough that the difference will be minimal, and probably undetectable - but using the term "well designed" for anything from Joseph Lucas is a bit shaky to say the least.
    Queensland
    I don’t know the exact reason for not sourcing power for the headlights at the alternator but when you consider that auto makers will do just about anything to save money yet even though many in many vehicles, the distance from headlights to the alternator is shorter than the distance to the battery, I only know of one specific vehicle that has come out with the power for the headlights being sourced at the alternator.
    Back in the 80s, VW golfs started coming out with the headlights being power from the alternator. This only happened for a short while and VW went back to powering them from the battery.
    This is just a guess but as the battery also acts as a big spike suppressor, having everything come of the battery, allows the battery to give the alternator some protection.
    Cheers.
    Cheers.
    The battery acts as just an efficient spike suppressor via the alternator - battery wiring, which has negligible inductance. I would also point out that in the 110, and I suspect the Defender, although I have never checked, the only lead to the battery is from the starter solenoid, and all other power is taken from there - which is actually closer to the alternator than it is to the battery, although probably about the same as the wire goes.
    I suspect the main reason why headlight wiring goes from a more central point such as the starter rather than the alternator is simply for ease of design and assembly.
    I suspect that the major reason
    Toowoomba, Queensland
    Last time you had this conversation, drivesafe and JDNSW, (about 12 months ago?) I went to the trouble of doing a circuit diagram. Everything is still in the loop - alternator, battery, lights - whether you wire from the alternator or from the battery. It's just which end of the alternator-battery wire (or in the middle?) that you attach to.
    If there was an issue with what was "nearest" to the current draw, surely it would be the negative side of the circuit that should be considered, being the electron donor?
    Steve
    2003 Discovery 2a
    In better care:
    1992 Defender
    1963 Series IIa Ambulance
    1977 Series III Ex-Army
    1988 County V8
    1981 V8 Series 3 "Stage 1"
    REMLR No. 215
    Oct 2006
    Boronia, Melbourne
    What forms of payment do you accept?
