Results 1 to 10 of 11
Thread: Yellow Pezza Ute Conversion!
    Well I have finally decided to turn yellow pezza into a Ute. I have started to acquire most of the parts such as the rear cab section, Ute tray rear door, and other little bits. The only part I have not got yet is the roof section, But I have decided to use the front slanted style roof section off my SWB hard top, and fabricate the back section of the roof to match with the rear cab. I think the standard ute roofs are to flimsy, and the dome shape dose not match the rest of the bodywork too well. the other reason is the overhead pannel i made will also not fit the dome roof. So all in all I think there will be less work involved in modding a standard hardtop roof. I will post pics of some of the parts I have started on shortly. If anyone has any suggestions for such a conversion, don't hesitate to post. stay tuned!
    Paul
    don't do it. the yellow box is a great look.
    Safe Travels
    harry
    At the moment having it as a Ute will be more useful to me, I will still keep the hard top if I ever decide to change it back again, with all the parts at hand it only takes a few hours to replace any way. I was planing to take the windscreen off some time soon to fix up a few small rust spots before they get out of hand.
    Well here are some pics of what I have got so far:
    The rear cab section prior to stripping and priming
    The rear section after etch priming
    rear section corner strengtheners after priming
    Tail gate from my SWB, most of the paint removed. What are the chances of stripping back the first layer of paint and finding the paint underneath matches
    yellow pezza.
    Tail gate latch repainted and installed on yellow pezza, only installed now because i wanted to test my new pneumatic rivet gun
    So far the only bit i have had to buy is the Gal. steel base for the cab roof, only paid $10 for it anyway. I will also buy new rubbers and windows etc. shortly as well.
    Warburton, Victoria
    Keep us informed.....
    Should look a Treat......
    Keep it yellow thou......
    Quote Originally Posted by sclarke View Post
    Don't worry mate, there is no chance in hell i am changing the colour
    When i removed all the cr@p I had in the back, and took out the false floor and water tank, she went like the clappers, probably about 200kg of weight taken out. Can't wait for when I take the roof off too. the water tank will go back in, along with a easly removable false floor. I might install the fuel tank out of my SWB in the back as well. hummm, That will be like 220L of diesel. I might almost be able to make it down to Cooma and back on one load of fuel, ha ha
    hmm, 'the rear section after etch priming' in? 'mirrortone 631 etchprime grey' perhaps. which is really good primer.
    the tailgate latch looks like a really good fit, shame it's going to get chipped.
    still liked the yellow box.
    Safe Travels
    harry
    Quote Originally Posted by harry View Post
    Yep your right about it getting chipped, I realized that after i painted it, I will put a rubber washer on the pin, and one on the back of the ring it fits onto, that should stop it getting too bad. I have to say it was a lot easier than i expected to put the latch mounts in. Drilled out the rivets, tapped the old plate down and out, tapped the new one back in again and its done.
    Wasn't mirrortone i used, but it would have been a better paint to use. I could have even got some from work too It dose look a bit like mirrortone because of the camera flash.
    Bracken Ridge, Qld
    paul - good stuff. I like these ute conversion threads.
    As I said in my post on clarkie's thread I want to convert my trayback to a ute tub type.
    Did you need special rivets to suit the LR or are standard rivets fine ?
    That pneumatic riveter sounds the goods.
    Where in Brissie are you .. nudge nudge wink wink.
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Quote Originally Posted by VladTepes View Post
    Hey mate. The rivets i was useing are just standard sealed aluminium. Unfortunatly the air riviter could not quite handle the 6.4mm ones, so i had to go down a size.
    They don't really match the Landy ones perfectly but it dosn't bother me too much. The air riveter is only one from supercheap but it dose the job. If you want a matching rivets you would have to use solid rivets with a proper impact riveter and dolly, a bit to much trouble to use in such a situation and takes a bit of practice. I am in Brookfield, Western Suburbs
