Results 1 to 10 of 16
Thread: Common Replacement parts for 4BD1 - sourcing
    Singapore via Melbourne
    I thought it would be good to kick off a thread listing sources of common parts for the 4BD1...
    In Melbourne:
    Patterson Cheney Trucks:
    200 Cheltenham Road Dandenong 03 9215 2300
    open 0830 - 1730 mon-fri
    Westar Trucks:
    150 Whitehall St, Footscray 03 9689 7611
    open 07:30-19:30 mon-fri, 7:00-12:00 sat
    Westar Trucks:
    Cnr Hume Highway & Northbourne Rd, Campbellfield 03 9305 3155
    open 08:30 - 16:30 mon-fri
    www.isuzu.com.au for the rest of their network
    they don't have everything for the 110 version as some ancillaries are not isuzu sourced, however if it is bolted to the block (not attached via hoses) they will definitely have it in stock. For hoses and the like, I typically go through fwd.com.au
    The few engine parts I have needed came from Fred Smith in Melbourne. Starter was overhauled by a local auto electrician who had no problems getting parts, same for alternator.
    I have found that the thermostat listed for this engine by Repco is not the right one.
    Jul 2007
    Pilbara
    I have bought a few parts from Zenith Enginering (Isuzu industrial engine importers) in Brissie. Apparently they made some of the very first adaptors to fit Isuzus into early Rovers. I actually bought the last one they had. They had to make a couple of parts to make up a complete kit. Bloody good service and knowledge.
    I have a project Isuzu 120 underway and cann't source the alternater and a/c compressor brackets.
    The bracket that I have for the alternater wont allow me to fit the a/c so I need both from an engine that had a/c.
    If these cann't be found is it possible to cast them from a borrowed set of brackets?
    I brought some brackets from a truck and they are very different to the landrover ones and dont allow me to fit the larger a/c compressor.
    Thanks, David.
    Nov 2006
    narellan, sydney
    I looked at pulling off my ac bracket a while ago, the compressor was chucked long ago. However, it seems it was bolted on before the engine was installed. Id give it to you, but i'm not pulling my motor out to remove it. I'm in Narellan if you want to come and have a look at it though.
    Andy
    Quote Originally Posted by defenderbilby View Post
    Thanks, David.
    I have a totally non-standard compressor set up if you are interested in photos?
    Thanks John, PM sent.
    Rather than emailing you the picture I am putting it here so others can see it. Not really very easy to see the setup, but this should give a reasonable idea. The bracket mounted on a couple of spare tapped holes in the head, and has a threaded adjustment onto a similar unused hole on the timing cover, cranked to keep clear of the alternator. Note the hole in the bracket for the heater pipe.
    Thanks John, that gives me another idea to play with. Hope your feeling better after your fall yesterday.
    David.
    Pomona Queensland
    Filter
    changed the oil cartridge today and had to use a cartridge listed as a 4bb1 motor...cartridge has hole one end size of 5c piece other end about 1 1/2"...4bd1 cartridge has holes each end the same, and smaller than the rod that screws into pump...anyone experience this?
