Thread: Stop stuff starting at start up?
    Yinnar South, Vic
    How does I do it?? where do I go??
    I mean when stuff starts at the startup of windows, like installed stuff likt kodak software etc
    Takes bloddy 10 years for my puta to finish starting
    Talk dumb please
    Jimboomba, QLD
    First place to look is in Start --> All Programs --> Startup.
    Anything in there will run on boot. Just right-click and delete what you don't want.
    If it's not in there, it will be in the registry. Usually not to hard to find. Try the above first.
    -- Paul --
    | '99 Discovery Td5 5spd man with a td5inside remap | doesn't know what it is in for ...
    | '94 Discovery Tdi 5spd man | going ... GONE
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    download ccleaner.
    install and run
    under tools goto startup.
    highlight and remove what you dont want to start at boot up.
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Yinnar South, Vic
    Geez, that was easy
    Thanks very muchly
    Yinnar South, Vic
    Quote Originally Posted by incisor View Post
    download ccleaner.
    install and run
    That one looks scary
    MarknDeb Guest
    i had the same problem with it, i ended up uninstalling it and using Adobe Photoshop Album Starter Edition
    you can also got to
    start > run > type MSCONFIG then enter
    select the startup tab
    untick the stuff you dont want to start.
