Results 1 to 10 of 16
Thread: Rocker Cover Vent
    Oct 2006
    Rocker Cover Vent
    Hi all,
    On my V8 S2 Disco it has the breather tube from the rocker cover vent plumbed into the bottom of the airbox. I'm sure this is good in thoery but i'm finding that as a result my air filters are clogging up rather quickly from the oil vapour mixing with the dust being sucked into the airbox and killing my filters ?
    Anyone experience this ? Is it just one of those problems that i live with ?
    Have thought about putting in an oil catch can or just putting a rocker breather/filter directly ontop of the rocker cover ?
    That seems an odd place to vent it. Normally it goes downstream of the aircleaner and the MAF sensor (you don't want oil on the sensor) - but I haven't looked at the Thor engine.
    Has your car been converted to LPG where the fitter has moved the hose?
    Ron
    Oct 2006
    Yea i thought it was a strange place for it to be installed but i had convinced myself that i had just not noticed it in the past ? Funny you should mention the LPG installation as i have noticed it to be worse on airfilters since the LPG installation - so yes i would say that they have taken it upon themselfs to move it there.
    Cheers Ron
    I was at Davis Performance Landys last week and Bruce Davis looked at mine and said that the crankcase vent didn't need to be moved on RR V8s. (Mine is downstream of the MAF sensor)
    The reason for moving them was to prevent LPG filling the crankcase under some situations with the subsequent risk of an explosion.
    It's been common practise for LPG fitters to move that hose - it could be a carry over from the days of carburettors.
    Ron
    cut the hose and add one of those $3 filters from an cheapo auto shop so that the natural air flow goes Up through the filter it'll slow down the leak immesurabley.
    If possable place the filter so the whole filter and hose from the rocker naturally runs downwards to the rocker with no traps in it and in all likely hood you'll never have to change the filter either.
    Avoca Beach
    Is the Disco a Thor?
    If so it pulls air from the front of the manifold after the throttle body. There should be a 1 way valve in the hose.
    The vent is also on the LH rocker and vents before the Throttle plate, on the rear of the throttle body.
    So the LPG installer must have moved them.
    I do not know where you could put it without a problem if it has to be before the LPG mixer. I assume you have an older type LPG conversion.
    maybe put a catch can a seperator in the circuit, and then change the position on teh air cleaner housing to after the air cleaner. You will still ahve a problem wit h the MAF. If you have room , put it between the MAF and LPG mixer.
    Regards Philip A
    Mar 2007
    perth western australia
    Would blanking where the hose vents into the manifold and just before the throttle body cause any problems as I have just been out to have a look at mine and am considering two small filters one for each side (Sorry for hijacking thread ) I have a problem periodically which seems like flooding only when turning a corner .
    Would this be caused from oil on the MAP sensor ?
    Quote Originally Posted by Ken View Post
    Im not sure if I understand your plan exactly but a generic warning.
    The crank case vent is there to get the small amount of blowby you get during combustion out of the sump. If you leave it there eventually your oil turns acidic. Which admitedly makes for very nice shiney engine internals but sadly is not conducive to long engine life.
    short version.. Dont totally block the breather dats bad.
    Mar 2007
    I want to put a filter on each vent hose that protrudes from the rocker covers themselves
    These tubes vent into just before the throttle body (Passenger side )
    And Into the manifold (Drivers side) if I blank off the points of entry I shouldnt have any problems ?
    Avoca Beach
    I do not see how the crankcase vents could have any possible effect on a miss while going around corners.
    When you ( I presume) last asked, I suggested a diagnostic. I still do.
    regards Philip A
