Results 1 to 10 of 37
Thread: New 2007 Defender pics from MT.Gambier show.
    Ruslan Guest
    Hi All,
    Here are some pics of the 2007 Defender from todays MTGambier Show
    ECU behind engine
    Under driver seat compartment. Good spot for an air compressor or car PC
    Anti-roll bar here...
    ... and here
    Rear seats mounting point
    Front passenger floor. See the heater outlet lower the speaker and plastic cover with 2 screws (might be fuses there)
    Hand Break drum position lower chassis
    Battery breather
    Missing bolt crossmember-gearbox or special future?
    Engine sump.
    Engine sump front view.
    That's interesting! DIY mounting tapped holes here...
    ... and here
    Some sort of plug on top of the TC
    Ruslan
    Mornington Peninsula and Hong Kong
    Is that in Stornoway Gray?
    Not real impressive about the cross member bolt.....
    How are the comfort levels?
    Great report by the way!
    Warburton, Victoria
    Well done.....
    nice pix...
    We have a problem guys...
    It seams that Mcdonalds now sell Defenders...
    I'll have a Mac Defender with a large Fries and Chocolate thick shake
    Quote Originally Posted by Ruslan View Post
    Hi All,
    I prefer the one on the right, can't think why
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by def90 View Post
    I would say that bolt is only for locating the box in a cradle or jack for fitting/ removal.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    brisbane
    And not a spot of oil under there.
    Tony
    Bexley NSW - Sydney
    Quote Originally Posted by redrover3 View Post
    Tony
    Must be a fake one with a plastic engine for display only ... no oil .. no LR ..
    Yinnar South, Vic
    Adding to the funny crossmember
    Pic 5. cable ties holding engine wiring harness, also ****fully run through the engine bay
    Pic 23. Joiners in the middle of hoses with untidy clamps
    When will they stop building vehicles that end up looking like one of my engine conversions
    Defender=1st Guest
    Thanks very much for posting the pics. Very nice looking Fender
    Ruslan Guest
    Quote Originally Posted by Numpty's Missus View Post
    Did you try the rear seats? Would be interested to know if they have made them comfortable enough for more than a 5min trip
    Very comprehensive set of pics there
    I did, not like a sofa but seems better than before. Personally I prefer sofa style without any pre-molded corrugations for back side profile where you can make you own deeps
    Sorry for pics/colours quality, yes, it is Stornoway Gray.
    Here is some more info
    Pitty, no low rev pulling power compare to remapped TD5, some correction/remapping required...
    By default a selector positioned between 3rd and 4th
    I do not have AC button picture (lower that control panel), in short words AC starts working after pushing that button even if speed switch in position "0". One of advantages of new ventilation system you can select now (like in most other cars) to use cabin air to circulate/cool down.
    That tweater(s) helps to get an idea what is on a radio while doing highway driving.
    Other thing, I think very important, all doors are still, fitted better than before and opening/closing procedure much easier now. What worries me is rust can go easier too.
