Results 1 to 10 of 14
Thread: no drive
    Apr 2007
    no drive
    86 model range rover 5 speed cannot get car to drive tailshaft spins when i put it in gear low /high no movement whats broken
    S.W. Sydney
    try puting the diff lock in and see what happens
    T
    99.87 MB
    Which tailshaft spins. Sounds like a broken diff or axle at the end with the spinning tailshaft. As said, locking the centre diff should get it moving again, but you'll need to get it fixed.
    Slunnie
    Yinnar South, Vic
    ^^^^^^x2
    Broken centre or axle
    Edit: if you want diff centres, axles etc I can help out, even have a full 24 spline set from a disco, or stock replacements, 10 spline stuff can be had for beer
    Quote Originally Posted by rovercare View Post
    ^^^^^^x2
    hrrrmmm sounds like your going to be my goto guy when i start building the 8x8x8...
    Warburton, Victoria
    Diff lock is in and both Spin... we pulled the CV on the Drivers side and axle is ok.. after that we gave up, put it back together and he got a Tow truck...
    S.W. Sydney
    unless you'v done a axle on both front and rear or both diffs
    its gotta be in the box but then why would the tail shafts spin...
    interesting....
    T
    lokka Guest
    Sounds like both diff centers have given up being a 10 spliner it woulden surprise me tho as ive done it busted back center and took teath off front crown wheel tho i could still brive it with a few clunks
    or hes blown a rear axle and the front diff....
    mcrover Guest
    Axels or centres or combination of both.
    My moneys on the diff centres if they are standard they are not overly strong espesially if running big agressive rubber.
    What tyres were you running and how did it happen might give some insite.
