Results 1 to 10 of 13
Thread: The best $20.00 ever spent.
    Blue Mountains
    Hi all, the best $20.00 I've spent on the Landy so far, is for a 'Heat gun', from an electronics Richard Smith person, and some heat shrink tube, of various sizes, which really finish off any wiring job, and makes it look fantastic, as we all solder our joins, don't we? Tee hee...
    Maleny, Queensland
    Just remember to put the heat-shrink on BEFORE making the final connection
    (I speak from experience - repeatedly)
    Kyabram, VIC 3620
    i use the wifes hairdrier - works fine
    Singapore via Melbourne
    cigarette lighter does too if you are careful
    Doreen, Melbourne
    That's a good cheap addition to the tools and will be handy.
    I use a butane gas soldering iron - one of the best tools I own. It is so handy, not to mention a go anywhere tool. Radiator repair etc. This is the unit I have http://radum.com.au/shopping/product...b98b6675331d94
    '01 D2 V8 4.6 Auto 7 Seater ACE
    Town Car - '11 Ford Mondeo Titanium TDCi -
    LROCV Member
    Quote Originally Posted by solmanic View Post
    Experience is what prevents a person who has made the same mistake twice from admitting they have just done it a third time.
    Adelaide, SA
    Quote Originally Posted by vnx205 View Post
    I think I must be up to about 30 times by now, the other is when the heatshrink size your using is only just big enough and you slide it down over the joint to quickly and it starts to shrink on the hot solder. Doh
    Island
    Quote Originally Posted by cookiesa View Post
    ..Or the heatshrink you have to hand really isn't big enough and you should go buy some more but you don't have time, so try it anyway; and so it jags a little, then friction heats it enough so it jags a lot, then you give up and gaff the joint with old fashioned leccy...
    A recently rushed DB install..
    Apr 2007
    Mooroolbark, Vic
    Quote Originally Posted by LandyBen View Post
    Too many times i've pulled a car stereo out and found wires twisted together .
    As an electronics guy, i solder (and heatshrink) all my joins. But is this an "accepted" method (eg. when the auto elec looks at it next time )?. I don't understand why they use the crimp spade connectors.
    I've done all of the above mistakes with heatshrink and i use it every day . What about when you shrink it down and its too big for the wire, and slides freely up and down the join ...
    Ermington, NSW, Au
    A good gas soldering iron is handy. Most have various heat gun nozzle attachments.
    2012 110 Defender
