Results 1 to 10 of 12
Thread: disco 1 stereo question
    Apr 2007
    Newcastle NSW
    Hello all,
    Quick question. I have a 98 SE7 Disco tdi. I have finally gotten around to replacing the standard tape deck with my Kenwood Cd player. Problem is I have no idea of how to remove the original tape deck. It looks like you need a special tool that fits through the four holes in the front face of the tape deck to unclip it from the dash. Does that sound familiar to anyone??
    Any help would be thoroughly appreciated.
    Goldey
    Jul 2007
    Blue Mountains NSW
    Yes its a small tool that can be used for lots of different stereo's.
    Need to find some small flat bits of tin or somthing similar about the length of a paddlepop stick, or maybe some realy thin screw drivers, slide them in and pull out stereo at the same time.
    Christchurch NZ
    My jap import disco had the factory land rover (pioneer) head unit and it was held in with very small cap screws (allen key required) through 4 round holes near the corners of the face. Is that what you have?
    1995 Defender 110 300TDI :D
    1954 86" Series 1 Automatic :eek:
    Ex '66 109" flat deck, '82 109" 3 door, '89 110 CSW V8, '74 Range Rover, '66 88" soft top, '78 88" soft top, '95 Disco ES V8, '88 Surf, '90 Surf, '84 V8 Surf, '91 Vitara.
    Adelaide Sthn Hills, South Australia
    Hi Goldey,
    The photo below should help you to understand what's going on behind those little holes in the front panel - I presume you've got the Eurovox radio?
    4 small screw drivers inserted to a depth of about 25mm will work nicely. You just have to juggle them a little (sideways) to get the tabs to release.
    The proper tool is just a U-shaped piece of rod so that one leg feeds into each of the two holes on one side of the radio - it's not much easier than the 4-screwdriver method.
    GrahamH
    '65 SIIa 88" Hard-top, Rego DW622, 186 Holden, 4.3 diffs (she's still back in NZ)
    '88 4-door Rangie (long gone)
    '96 Disco SI 3.9V8i (LPG) Manual (Inspector Rex's kennel)
    '03 Disco SII TD5 Auto (the serious camping car)
    '15 Disco 4 3.0Lt TDV6 (was a dog-hair free zone - not now!!!)
    I'd Rather Push My Land Rover in QLD Than Drive A Toyota in NSW
    Two other options,
    A piece of wire coathanger bent into a U shape and just wiggle them around till the clips disengage, I used this when I removed the original unit in mine and replaced with a Kenwood Head Unit.
    The second is 4 kebab skewers, works as well but a bit harder to manipulate.
    Apr 2007
    Newcastle NSW
    Thanks guys, exactly the info I was after.
    Goldey
    St Helena,Melbourne
    4.28 MB
    Did you get an aerpro loom or using the cut and join method ?
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Apr 2007
    Newcastle NSW
    It would be the cut and join method, is there a better option?
    Goldey
    Dalby
    If you don't want to buy an adapter cable then you can solder to the existing wires without cutting them or you can use crimp connectors and insert them individually into the existing plug.
    I'd never cut the original plug out. It might cause you some pain later on.
    Kedron
    4 50mm decking nails fit perfect. Grab the unit by the tape slot and wiggle out.
    And now for the hijack.my deck has been dropping in and out of power. I have checked the coneections and all looks fine. Is this a sign that the unit is stuffed? I hope not because we resently replaced the stacker and it might be hard to get a new uinit with stacker controlls
