Results 1 to 10 of 22
Thread: UHF Aerial onto Defender
    Maleny, Queensland
    I am starting to get my accessories organised for the new Defender when it arrives and need to know where is a safe and secure mounting spot WITHOUT a bullbar.
    If there is in fact no guaranteed secure spot then I will just fit a bar, but I thought I'd ask the question before haemorrhaging more money.
    May 2002
    Sydney, Australia
    how about on the passenger side guard - mirror image to the radio aerial, maybe a bit tight with the heater?
    LRH
    Disco 4 SDV6 Auto
    Disco 4 SDV8 Dual Cab Project
    Disco 2 M57 Extra Cab Project
    Foton Tunland Cummins ISF
    Disco 1 3 door 4.6 V8 Auto
    RRC V8 Auto "Classic" Softdash
    RRC 300 TDI Auto
    Disco 1 TD5 Auto Buggy
    Disco 1 300 Tdi Auto Ute
    SAME Explorer 70HP 4x4 Tractor plus Nell Loader
    Subaru GDA WRX
    Triumph Bonneville SE
    Yamaha TTR250
    Apr 2007
    Sydney city
    Since I got rid of my bullbar, I mounted mine at the front of the driver's side gutter - nice and clear of any obstructions.
    The cable runs along the gutter to above the B pillar (held by a little metal clamp,) then into the top of the hollow back door-seal, exiting at the bottom, where it pops into the cabin (there's a convenient gap there on my County.)
    From there, it runs behind the driver's seat rails, to the centre cubby box.
    I can screw on a short whip for close bush work, or something longer to get over the dunes.
    I was going to mount it off the gutter above the rear door and run the cable in somewhere around the door seal, but I didn't have enough cable at the time - plus above the driver's door is remarkably convenient for getting the antenna off in tricky situations.
    Maleny, Queensland
    I'm not too keen on mounting through the bodywork anywhere, so the roof gutter option appeals to me.
    The more I think about it though, the more I reckon I will just get another "big" aerial and fit another bullbar and be done with it. I guess that leads me to my next query, which should get a new thread because it doesn't belong in communications - are there any local front protection options other than a full bullbar?
    May 2002
    Sydney, Australia
    how about just installing a nudge bar like DiscoWhites and Reads90 had?
    Disco 4 SDV6 Auto
    RRC 300 TDI Auto
    Subaru GDA WRX
    Yamaha TTR250
    Blue Mountains
    Hi there, as above, you could use an 'A' bar or similar, as this would be cheaper than a full blown steel winch bar, although this bar would provide more frontal protection. The aerial I would suggest is a ground independant type, with a spring base, which is hollow to allow the coax to travel through. This aerial is the same as types used on taxi's and police cars etc. This allows you to screw on various uhf aerials (small stumpy or approx. 40cm steel type), to suit your needs. The spring would help with branches and the like, that glance off the front. Cheers, Ben.
    Wheelers Hill, Melbourne
    I have a UHF aerial base that fits on the windscreen base, from the County I am dismantling. Going real cheap . Downside is that you have to drill thru the hinge and maybe the firewall. With UHF, wherever you place it, bear in mind it uses the vehicle as a ground plane and the best pozzy for all round reception is the middle of the roof.
    I'm assuming the brackets the same on the new deefer
    Pics attached
    Sydney, NSW (nr Epping)
    Quote Originally Posted by DeeJay View Post
    Pics attached
    Hi DeeJay, That's not strictly true. By using a ground-plane-independent antenna, placement is less critical. You do still benefit, however by placing the antenna as high as possible on the vehicle.
    Normanhurst, NSW
    Not sure about the 2007 'Fender but I mounted mine where the blanked off vent is on the top of the drivers side front guard. Replaced the original cover plate with a piece of 8mm plastic cut to size/shape of original cover then mounted UHF Aerial and hot shower outlet tap.
    See attached pics - don't seem to be able to attach anything. Will try putting in my gallery.
    OK - Pics in gallery
    Roger
    Smile Whoops
    Quote Originally Posted by Xtreme View Post
    Hi Xtreme.
    The shield of the antenna cable needs a good connection to the body at the mount site, if it is of the Non Ground Independant type - single contact 5/16 inch. Relying on the connection through the radio is not good enough.
    Even if it is of a Ground independant type - two connections: central fixed pin an a nut type sleeve 5/8 inch, a good earth at the mounting point is still advisable.
    A non insulated metal plate (aluminium) without paint is good.
    Beware of using sisalastic/silicone and also of using stainless screws for this job due to electrolysis.
    Good luck, Rovers4.
