What is the best power source for a winch on a Defender. Going all the way to the battery under the seat makes it a long cable run. A second battery install under the bonnet could be a way but where to put it?
Mine also works fine. Though I mostly go 4wding with other Landies so don't get to use it much.![]()
straight to the seatbox is the easiest option.. just make sure you get a Traxide dual battery system in and you're sweet to go![]()
EVL '96 Defender 110 - Emerald '63 2a Ambulance 112-221 - Christine '93 Rangy - Van '98 Rangy - Rachael '76 S3 GS - Special '70 S2a GS - Miss B '86 Rangy - RAAF Tactical 200184 & 200168
Hoping to drag me out at Xmas time Graz
May have a pootrol to join us if its ready for my mate in time,you may get to drag it out
Andrew
DISCOVERY IS TO BE DISOWNED
Snow White MY14 TDV6 D4
Had no issues with mine.
The way I load up the camper trailer, ( Booze, fuel, toys, grog, fishing gear, water, alcohol, oh and food ) I'm more likely to be winching myself out!!
Likely to end up with Tojo farm ute and a muzzo as well to recover,
Thanks for the replys. As advised, I run a cable down the chassis rail, when I find a winch bar.
I think I saw a Defer winch bar in the markets recently
No problem with it in the battery box.
I think you'll find that's where almost everyone runs the cable to (Including LR Special Vehicles).
HTH
M
