Results 1 to 8 of 8
Thread: Converting VHS to DVD
    Lesmurdie - Perth WA
    Hi
    I am looking at ways (least painful) that I can turn a stack of home vidios on VHS tapes into DVD.
    The tapes have various good bits I want to keep though they are surrounded by a lot of rubbish that needs to be editored out.
    I note the thread on MAC computers to turn tape into DVD however my laptop is Microsoft.
    I checked at JB HiFi and they had a six head VHS player and hard drive combination. I was advised that I could edit the content of that drive when I tranfered it to my laptop.
    Appreciate any suggestions
    Alstonville...is near Byron Bay
    There are a number of ways you can do this.
    VHS machine outputs directly to your computer - you may need a dedicated video card in your computer.
    Get a decent edit package (which will have a video/audio capture function) and an external hardrive of about 500gigs, they're pretty cheap these days.
    You'll need to setup the system prior to capturing.
    Most edit systems default to USA tv standards check and set before capturing.
    Set for Australia: PAL - D 625/50
    Screen size: 768 x 576
    Frame rate: 25 frames per second
    You can chuck all the data onto the external drive and edit away to your hearts content.
    Unless you have very fast computer, go easy on the graphics and special effects.
    If the VHS tapes haven't had a run for a while it's a good idea to run them (fast forward/rewind) thru the machine a few times.
    I like the idea of having a VHS machine where you can dump data from VHS to the inboard hard drive, but you'll need to ensure this device can talk (easily) to your computer (as PAL - D 625/50 at 25fps) for later editing purposes, and ultimate playback on your telly from DVD...
    I'm assuming your VHS tapes are older and pre the change to HD/widescreen.
    One other thing, VHS is a rather unstable system, however you go about capturing from the tapes,
    ensure that the capturing device is capable of handling VHS's rather wobbly playback... or you'll get very frustated capturing. Some systems I've seen stop capturing every time there is a break in VHS control track or synch.
    If you buy the VHS/HDD, get the seller to actually go thru the capturing procedure from one of your tapes.
    Should work fine, but.......
    Good luck, and keep us posted.
    GQ
    Brisbane, north of the river
    or do what I did, get yourself a DVD recorder with inbuilt HDD.
    Play your VHS and record it directly onto the HDD of DVD recorder.
    From there it's easy enough to edit out the bits and pieces as required and then burn it to DVD.
    No laptop required
    Melbourne, outer South East
    Quote Originally Posted by Grizzly_Adams View Post
    No laptop required
    those DVD recorders with inbuit HDD are really cheap now too ....
    e.g.
    http://www.dealsdirect.com.au/p/coni...r-dual-format/
    dvd vhs
    jaycar used to have a device to convert analogue to digital approx $115
    Warburton, Victoria
    Or Buy a DVD Recorder/ Settop box that has a Tuner and S vid and RCA in....
    Ohh i happen to have one for sale.....
    PM me if your interested...
    Jimboomba, QLD
    If you don't need to edit the video and just want to go straight to DVD, JB HiFi sell a small DVD recorder that has AV inputs. It is designed specifically to convert VHS to DVD.
    We've just bought one for work, but I haven't had a chance to borrow it yet to do my videos. Once I have used it, I'll post some more details.
    -- Paul --
    | '99 Discovery Td5 5spd man with a td5inside remap | doesn't know what it is in for ...
    | '94 Discovery Tdi 5spd man | going ... GONE
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    Quote Originally Posted by alanbettison View Post
    was good except it never latched the audio to the video and it got out of sync a bit at times.
    canopus make a box that does latch them but is marginally dearer.
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
