Results 1 to 10 of 14
Thread: Workshop Manual?
    Perth, WA
    Workshop Manual?
    Is there an electronic D3 manual? I'm specifically after wiring diagrams, but instructions for taking the dash apart would be useful too.
    Jeff
    1994 300TDi Defender
    2010 TDV8 RRS
    Probably downloadable from the Land Rover Global Technical Reference. I've logged on there for a day and got all I needed for the P38A.
    You have to pay a fee but it's not excessive.
    Oh, when you've got it, let us all know......
    Queensland
    WHY?
    WHY?
    Just in case YOU need a copy, Tim!
    Perth, WA
    Thanks Ron....but what are you doing in the D3 section?
    Jeff
    2010 TDV8 RRS
    I've used the LRTR website for both the D3 and FL2 to get the wiring diagrams but for the D3 I'd suggest you subscribe for a month so you can go thru all the info on there.... theres quite a lot.
    As for pulling the dash off the first step is quite simple.
    Grab the peice of plastic that surronds the audio unit & A\C controls down low either side of the A/C controls and pull towards the back of the car.
    There are clips inside of this peice that clip into the frame - try not to loose them.
    This will give you access to the audio unit \ ac controls, the ac vents and the cubby hole in the middle of the dash.
    06 SE V6 Discovery 3
    Quote Originally Posted by jik22 View Post
    I'm a Super Moderator - I roam freely!
    Also I have catholic tastes - I even like some other marques!.
    Adelaide Hills
    D3 manuals
    I subscribed for a month and got a lot of info. The wiring diagrams and training sections(theory stuff) are pdf files and can be downloaded as units. The workshop procedures can't be so you need to go to the relevant section and check out the procedures.
    Queensland
    Yep, that’s the plan
    Good thinking, Batman!
