Originally Posted by
Xavie
I'm considering something similar but are you putting a uhf or a 27mhz in?
I have heard that uhf aerials are not as good as 27mhz for stereo rx? was from an unreliable source however.
Xavier
Neither are tuned anywhere near the FM broadcast band (or AM broadcast), but the increased length of the 27MHz versus the 400MHz antennae (Note use of correct first declension plural, Ron) means that the voltage output from the antenna will be higher for the 27MHz antenna, but both should give adequate performance except in fringe areas.
