Results 1 to 3 of 3
Thread: Salisbury diff pinion oil seal
    G'day from stage 1 land!
    I have just replaced my rear diff oil seal and learnt the hard way a few tips that might help others.
    The driveshaft flange bolts are awkward and a 1/2" drive socket wont easily fit- a 3/8" one does 'tho.
    I made up a "flange holding tool" from some 1" angle iron with 2 holes 2" apart and a bit ground out of the edge to clear the nut. Well worth the 30min spent making it.
    The @#$%^% pinion nut is quite tight. I used (with thanks) an AULRO tip and used a bottle jack on the end of my socket drive handle- easily did it with no sweat and no barked knuckles. It is a normal right handed nut.
    The old seal is difficult to get out- just bends if a gear extractor is used. I found that a small tek screw in the edge of the seal provided enough purchase for a claw hammer (thanks to David for the tip).
    Dont forget to mark everything and count the turns
    Russ
    Feb 2005
    have done this myself....a couple of good tips there
    Nanny state UK...
    ...or a long breaker bar and someone standing on the brakes.
    M
