Thread: Door seals clogging with dirt
    Hey Guys,
    I have a question about my door seals in my defender..
    The problem i am having is that whenever you get in and out of the car there seems to be a lot of dirt falling into the door seals and clogging them up. It is a pain in the ass to get the dirt out of there and it just seems like a recipy for disaster, in the way of rusting?
    Any advice in this area would be great, or even a modification that can solve this problem would also be appreciated?
    Cheers Dave
    Geelong
    Dave, I bolted a 3*10mm steel bar along the flat part of the rubber. Obviously, dirt still accumulates in the crevice there, but it stops the seal being pushed out and little stones etc getting wedged in the gap.
    Cool idea, thanks for that. So did you remove the seal then attach your steel bar then attach the seal to the bar? Not sure visually how you have done it?
    - Dave
    Ferntree Gully VIC
    remove the floor seal and attach a seal on the bottom of the door......
    130's rule
    Geelong
    Quote Originally Posted by wheelie77 View Post
    - Dave
    My seals had been pop-riveted on, so when I drilled out the rivets, the seal came off. I then marked up the holes for drilling the steel bar to match the rivet holes - 8 for the front doors. Then bolted the support bar and seal straight on.
    St Helena,Melbourne
    4.28 MB
    Hey Guys,
    Cheers Dave
    You do realise that the dirt may actually improve the sealing ? Cant be any worse
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    That is possible but the rocks do seem a bit of a problem . It dosent really matter but it just seems like a little hiding spot for rust to start, and that is the last thing i want.
