Results 1 to 6 of 6
Thread: Mantec Front Plates
    Nov 2007
    Mantec Front Plates
    Are they available here? Or anything similar? Are these the G4 underbody protection plates in the accessories brochue?
    Melbourne, Australia
    Muppo,
    PM Simon_arch1 on the Disco3.co.uk forum he can supply.
    Simon is Melbourne based and his webstie is called 4x4intelligence.com.au
    Chris
    $700 seem a lot for what it is.
    Perth, WA
    Quote Originally Posted by muppo View Post
    Have you got a link to these? I'm in the UK week after next, so if I know what I'm looking for, can find them at any of the LR places I'm going (Stocking up on bits for the Defender), and if they don't weigh a ton, I may bring some back!
    Jeff
    1994 300TDi Defender
    2010 TDV8 RRS
    Sydney, NSW (nr Epping)
    Hi muppo,
    If you are considering fitting a bullbar at some stage, look at the ARB "Deluxe" bar. I've just fitted one and it includes an under bar "stone" guard to replace the useless plastic bit from LR and makes the retrieval "loop" permanently available.
    I think that the "stone" guard may be a bit light on, but forms a wonderful pattern for something heavier.
    Best Wishes,
    Adelaide Hills
    Cable exposed
    Quote Originally Posted by Bushwanderer View Post
    Hi muppo,
    Best Wishes,
    I just fitted the TJM bullbar and found that a cable for the air suspension which loops around the front chassis rail is exposed to road damage. It is on the drivers side and has a plug on it for the air suspension control block which sits in behind the bar. I also had a look at the ARB bar fitted to a D3 and while it is not exposed to the same degree there was a gap in the bar on the RH side of the chassis rail where a stick could enter and cut the cable, hence no air suspension. I made up a plate to cover mine. See pic for the cable in question.
