Results 1 to 10 of 13
Thread: D1 ignition key problem
    Nov 2007
    Doha Qatar
    Exclamation D1 ignition key problem
    I noticed that occasionally the ignition key would not turn in the lock. Now it will not turn at all, so no going anywhere right now. I don't have a remote locking key fob 'cause that died a long time ago, just the one key for the door and ignition. I need suggestions to fix the problem, how do I get the barrel out without breaking off the shear bolts on the steering yolk that holds the ignition assembly on the steering column? Do I need to do that in any case?
    All suggestions most welcome but not including buying another car!
    Viv
    Doha, Qatar
    Melbourne, outer South East
    Happens to me sometimes too so I'm watching the answers on this - it's tied up with the steering lock - for me rocking the steering wheel to one limit and then turning the key fixes it. But I know one day its gonna totally freeze up probably when I'm up bush somewhere. I heard a spray of silicone or graphite in the lock can also help.
    Have you tried using your spare ( less worn ) key ?
    To get to cylinder to try and fix it you can remove it without shearing bolts by carefully using small cold chisel on edge of bolt head to rotate them.
    Narrogin WA
    I managed to stave off these symptoms for two years, using powdered graphite and spray lubricant.
    In the end it caught me and I had to replace the ignition barrel; luckily it was at home and not in the middle of nowhere.
    Might be agood idea to change it now while it is in a hospitable place
    St Helena,Melbourne
    4.28 MB
    I had the same problem last year, lots of graphite powder and wiggling of the wheel and it came free, mine was the steering lock mechanism not releasing.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Blairgowrie, Vic
    Wear in the locking block (the bit that goes into the column) makes it get a little sideways and jam. What breaks is the KEY - so replace the mechanism and you'll fix the problem. A reputable locksmith will return the cylinder to your key pattern and if the cylinder is badly worn, it can be refurbished at the same time.
    Qatar is set for locksmiths???
    HTH
    Pete
    Dizzie, 08 D3 TDV6 SE
    Nov 2007
    Doha Qatar
    Quote Originally Posted by waynep View Post
    Yes the spare key is no good and trying to get a new key cut in Qatar is virtually impossible!
    Nov 2007
    Doha Qatar
    Quote Originally Posted by chazza View Post
    I was lucky too in that the truck was at home!
    Nov 2007
    Doha Qatar
    Quote Originally Posted by Pierre View Post
    HTH
    Pete
    Thanks for the info. I guess the barrel has to come out and I have to find a locksmith, that's the tough part here in Qatar
    Nov 2007
    Doha Qatar
    Exclamation Ignition key and barrel VIN #
    Hi All
    Thanks for the help on the key problem. I'm going to order a new ignition lock and keys from the UK (unless there's somewhere in Aus I can order from?)
    But there seems to be two types of locks sets depending on VIN # But my 1998 D1 is a Gulf only export model with a different VIN SALLJGMM8WA750972
    Any ideas?
    Viv
