Results 1 to 9 of 9
Thread: LT230 inspection cover
    Medowie N.S.W
    Does anyone know if theres a gaskit under the inspection cover of the lt230, i want to take mine off but wanna know if i need a new gaskit first or if i can just goop it up?
    Yinnar South, Vic
    Yes
    Kyabram, VIC 3620
    Quote Originally Posted by Wortho View Post
    If you are talking about the large rectangular plate - then no, there is no gasket
    In the manual it states
    "Apply Hylosil RTV 102 sealant to mating face of bottom cover.
    Use Loctite 290 to bolt threads, tighten in a diagonal seq to 25 Nm (18 L
    Medowie N.S.W
    Yes a gaskit or yes i can just put some goo on it?
    Medowie N.S.W
    Thanks.
    Rovernaut Guest
    The lock tight is very important though, if not used then you will get oil leaks from some of the bolts as they screw into the oil area
    very early on it had a gasket, It leaked so was later done away with and replaced with Goop. If you smear some goop on the threads of the bolts and let it setup for a few hours before adding your oil it wont leak but loctite is the better answer I think 517 master gasket/flange sealant would be your best bet being rated for a reasonable sort of temperature and being proof against most liquids (but its not sensor safe)
    Feb 2005
    As dave said, I have had mine off three times and goo has worked
    Medowie N.S.W
    Thanks guys, will do the loctite on the bolts and loctite grey max goop on the plate.
