Results 1 to 10 of 16
Thread: defender rear wheel carrier
    yackandandah, vic
    Hi all,
    I am looking at putting a rear wheel carrier on my 07 fender. I would appreciate any opinions/views on the various brands for sale. Do any of them allow you to lock the wheel in the open position?
    thanks
    just brought a bearmach one for ours fitting it soon will let you know how it goes
    its also greasable
    yackandandah, vic
    its also greasable
    where did you get it from?
    car kraft
    its for a post 2003 or something like that, not 07 specific but i believe alot of them getting fitted are td5 ones so brought it to give it a go cant see why it wouldn't fit
    Oct 2007
    I just had the opposite lock one fitted. I wish I could get some pics for you but maybe the boys at parramatta landrover will take them for you instead seeing they see more of my Defender then I....can you tell I'm sour??? hahaha.
    No, but when I get it back I'll get some pics.
    Xavier
    Albury, NSW
    Hi Kevin,
    I obtained my wheel carrier from WA - phone 08 93621744 - they freighted it to the front door - I think it was around $650 all up (might be $695)
    However, if you wish to have a look at it give me a call.
    But make sure you bring the Defender - I want to have a good look at that overhead console of yours.
    http://i271.photobucket.com/albums/j...KevsAvatar.jpg
    Defender '06 - (+ Tombie's Magic)
    Gone but not forgotten
    Defender 03 (Rolled)
    '99 TDI Discovery
    '96 V8 Discovery
    '86 V8 County (Life's regret selling this)
    Series III
    Ritter sell Bearmach and Scorpion Racing, Bearmach was cheaper and apart from the Hi-Lift jack mount, looked the same. Takes no time to install and makes a big difference to the door. Well it did on a 300Tdi Defender, so I'm assuming the 07 won't be any different.
    From memory the differences between a 300Tdi Carrier and a Td5 unit are to do with the door hinges.
    Quote Originally Posted by Barra1 View Post
    Hi Kevin,
    I paid $500 for mine. Mind you I also bought some other stuff at the time.
    May 2002
    Sydney, Australia
    may be of use D110 - Rear Wheel Carrier, mod of Bearmach
    been confirmed - 2007 rear door is the same as a MY02+ door
    HTH
    LRH
    Disco 4 SDV6 Auto
    Disco 4 SDV8 Dual Cab Project
    Disco 2 M57 Extra Cab Project
    Foton Tunland Cummins ISF
    Disco 1 3 door 4.6 V8 Auto
    RRC V8 Auto "Classic" Softdash
    RRC 300 TDI Auto
    Disco 1 TD5 Auto Buggy
    Disco 1 300 Tdi Auto Ute
    SAME Explorer 70HP 4x4 Tractor plus Nell Loader
    Subaru GDA WRX
    Triumph Bonneville SE
    Yamaha TTR250
    sydney
    make sure you get the correct model bearmach as there is three, unfortunatly we got the wrong one and i did not realise untill i had drilled the holes in the new defender. luckily it fitted ok despite what the web site said. so we have ended up with the none greesable model and its mounts more inboard than the newer model.
