Results 1 to 10 of 15
Thread: Rear Disc Brakes - 94 Defender
    Bracken Ridge, Qld
    OK so here's a long question...
    1. What's the process ?
    2. Aside from spanners etc and hub nut spanner thingy, are there any special tols I'll need ?
    3. Aside from pads and rotors, do I need any other 'bits' or consumables ?
    (for example, do I need to repack bearings etc when I put the hubs back on ? If so, how ?
    I reckon I'll have a crack at (just about) anything now !
    (saving money, you see!)
    I have tomorrow off so thought I might tackle it then or on the weekend.
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    If you're doing the rotors, then you'll have the bearings out, so better to repack them, and probably replace the seals at the same time, check this out for the one page instructions -
    Broken wheek stud
    EDIT Sorry, halfway there. You'll need gasketty stuff for the drive flange, new split pins for the pins in the brake caliper, cleaning things for grease and brake cleaner, umm, umm, umm.
    If you pull off the end caps of the drive flange it should give you a good idea of how much needs to be done - if it's all dry and muddy you might need to replace bearings as well.
    Just learned this one last week - To grease the bearings, get a walnut sized ball of grease in your palm, hold the bearing with your fingers hooked through the middle, and drag the edge of the bearing through the grease. Keep doing it in one spot on the bearing until grease starts coming out the other/top side of the bearing, then turn it a bit and drag across your palm again. This way you can see that the entire bearing race is filled with grease.
    Simon
    Safety Bay
    If solid disc's from a '96 disco fit I have a good set you can have for a good price eg Free. Pat
    You're going to tackle the rear brakes ????
    I thought you were nervous of doing an oil change.
    2011 Range Rover Sport SDV6 Autobiography
    2004 Freelander TD4 SE
    1997 Range Rover 4.6 HSE
    1994 Range Rover Vogue
    Bracken Ridge, Qld
    Quote Originally Posted by PAT303 View Post
    Don't knnow if they'd fit, and also I;m in Brossie! Thanks anyway.
    Quote Originally Posted by adm333 View Post
    GGF !
    I just need someone to watch me / help in case of major screw up / offer advice and I'll be OK. This goes with anything from an oil change to brain surgery.
    gone
    1996 Discovery 1
    current
    Quote Originally Posted by VladTepes View Post
    GGF !
    Oh, we'll all be watching and waiting.
    Didn't happen without pics.
    Simon
    OK I have gone and GF!
    I wasn't having a go......... I'm impressed.
    Have you got the RAVE CD / workshop manual.... that's usually a big help.
    Bracken Ridge, Qld
    somewhere.....
    gone
    1996 Discovery 1
    current
    Warburton, Victoria
    Question...
    Is your question on how to reco the rear brakes or convert from Drum to Disc???
    Is your 94 Fender a rear disc model???
    Clarkie
    Me wondering the same thing!!!
    If the rotors are ok there are not many vehicles as simple as landys to change pads on!! eh!.
    Sumo.
