Results 1 to 8 of 8
Thread: Disco 2 with SLS - How to lower withOUT key fob
    Guys,
    I was wondering whether it was possible to lower the rear of the car with a bypass switch or something if I don't have the special key fob to do so?
    Thanks,
    Auke
    Kyabram, VIC 3620
    From what I understand - you cannot.
    Unless you puncture the air bags
    A mate from the UK said be built a toy that alows him to do this, but he hasn't replied to my email requesting details - when/if he does I'll get back to you.
    ..............dont hold your breath though, he isn't very quick with email
    Quote Originally Posted by Aukedrdw View Post
    Guys,
    Thanks,
    Auke
    you can but it involves spannering and Im guessing is not the solution your after.
    unhook the airline from the airbag or the valve.
    If you want to make it easier to do in the future fit an airvalve in the line that will let you switch a port to atmosphere while you close off the other.
    May 2003
    On The Road
    I'm just wondering how common those special key fobs are???
    Oct 2006
    kinross, Perth, WA
    I have one pedro ... not that that gives you much help...
    thanks
    Steve
    May 2003
    On The Road
    is it a handy thing?? Mr and Mrs Pedro are not overly height endowed
    Oct 2006
    kinross, Perth, WA
    it only drops the rear down for hooking up trailers etc.. but quite handy it the drive in cinema so we can get a more pointed at the screen angle!
    to be honest they are the only 2 things i can think of that you could use it for!
    Steve
    Karratha WA
    Sitting inside with the doors closed and engine running, press the SLS button on the dash. The bags will inflate to max height. Once at max height press the button on the dash again and they will deflate. Once at the rear height you want turn off the motor and they stay there..or let them go right down.
    Also works if you have the drivers window down and you lean in and press button (with engine running).
    This is how I do it for my boat or van. Once you are moving the sensors and the SLABS computer work it all out for you to be level again.
    BradM
