Results 1 to 4 of 4
Thread: power steering
    May 2006
    Ulverstone,TAS
    power steering
    Was driving to work today and noticed that every time I moved the steering wheel from dead straight,it made a grinding sound.I checked the level in the bottle and it was just above 1/2 full.
    Besides the 2 hoses that connect to the resevoir,is there any where else I should check for leaks(the hoses look all brown at the moment,cause I have to replace the top hose on the radiator).
    Gazza
    Somewhere else, QLD
    Urgent trip to power steering specialist required.
    May 2006
    Ulverstone,TAS
    Booked in next Tuesday.
    2014 Freelander SE TD4
    2003 Range Rover TD6
    92 disco tdi manual sold
    95 disco tdi auto gone
    Avoca Beach
    Are you sure that it is not just the UJs on the steering column.
    This gives a very hard spot just off straight ahead, but not usually a grinding sound.
    To check , douse the UJs in CRC.
    Regard sPhilip A
