Results 1 to 10 of 34
Thread: 300Tdi throws timing belt - but why?
    Hoping someone can shed some light here...
    A few weeks ago my brother-in-law changed his timing belt in his D1. A brand new belt, sprocket and tensioner pully.
    250km's later she went BANG! ...damage was 4 broken push-rods and 4 valves.
    Upon removing the timing belt cover - the belt had shedded itself (see pics).
    Any idea's why?
    My brother-in-law offered the following description...
    "Photos attached. You can see the flange on the crankshaft sprocket had been ripped off. Cause of valve/pushrod failure was a shredded timing belt, cause of belt failure is tracking issues. Not sure why the belt did not track properly.
    The belt was installed to instructions as per difflock - however we did take the belt off after rotating it. At first my injection pump alignment pin was too large and was not locking in deep enough. We turned the engine over - but it would not fire because the injection pump was out of time. We removed the belt and reinstalled it again with the correctly sized locking pin. We didn't turn the engine over after this. Perhaps this was a mistake?
    During first installation, then belt tension idlers where replaced and tensioned with a torque arm. After failure, the idler bolts seemed ok - they had not loosened. Tension was still on the belt after the failure.
    Pulleys seem to be aligned with the naked eye. "
    Adelaide - Torrens Park
    Too tight belt tension will cause premature failure.
    Moruya Heads/Sth. Coast, NSW
    Quote Originally Posted by Taz View Post
    Any idea's why?
    Looks like a good reason to change to gear drive, anyone done this and at what cost, Regardes Frank.
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    would be a good idea IF there was a viable option available...
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by Tank View Post
    Google the Zeus gear drive kit, more failures and problems than a belt will give. Chain would be the best solution but that involves sealing the cover and comingup with a lubricating arrangement and then draining excess oil back to sump.
    Last edited by p38arover; 23rd January 2008 at 08:01 PM. Reason: amend spelling of Zeus
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Camp Hill Queensland
    What year D1 ?
    Didn't pre '97 TDIs have a timing belt mis-alignment problem ? Even so, sounds early for this to manifest.
    '95 110 300TDI, F&R ARB Lockers, Twine Shower, Aux Sill Tank, Snorkel, Cargo barrier, 9 seats, swingaway wheel carrier, MadMan EMS2
    '85 110 Isuzu NA 4BE1 3.6l Diesel, 0.996 LT-95, Rear Maxi (SOLD)
    '76 SIII 109" Nissan ED33 5-SP Nissan GBox (SOLD)
    Nov 2007
    Central coast NSW
    I thought there was a mod for this. Not sure if that engine has it but the crank pulley should have a lip either side of the belt to stop it coming off. The mod may even have it on an idler pulley to, can't remember. Ring Davis Perf Landys.
    Yes - mod kit was fitted. BIL says the damaged belt removed the flange on the crank sprocket.
    Jan 2008
    Ireland
    back in 1998 a problem of thes nature arose in new vehicles a recall was put in place and the vehicles were modified with these bits LHH100600/ DRIVE GEAR,LHV100150 IDLER ,LHP100860 TENSIONER. Brit part /bermach do these kits and to the best of my knowledge are the only ones that should be fitted not the earlier type up here on top the kit will cost 300 e . O! ya mind the tension too much breaks em eveytime
    JamesH Guest
    Nothing useful to add ,but my sincere commiserations.
    I lost a timing belt and did the same damage but it was 80 thou kms in and the dealer didn't think to tell about the known problem and the upgrade kit available.
